swapped motors, problems with speedometer
Old Dec 12, 2010 | 03:25 PM
xcoltonx's Avatar
i swapped my 305 tpi for a 350 4bbl in my 86 T/A. i ripped the computer and wire harness from it with the old motor and realize the speedometer is run through that ecm from the transmission. anybody ever had to put in an aftermarket speedometer on one of these? or is there a bypass harness i maybe able to come across? help please
bbm: Pin: 31222FEC chat about cars on blackberry messenger. just add me
Old Dec 12, 2010 | 04:24 PM
White'89's Avatar
Car: '89 GTA
Engine: 5.7L LS1
Axle/Gears: 9 bolt 3.27
Re: swapped motors, problems with speedometer
I'd look up the pinouts for the C100 in your car. My 1989 Tpi car had both the VSS wires routed straight to the C100 and into the dash to the gauge.
Old Dec 12, 2010 | 04:43 PM
xcoltonx's Avatar
more or less what im asking, i found the wires in the harness. is there a way to skip the computer and wire straight from the tranny to the speedometer?
Frozer!!!
Jan 19, 2024 04:55 PM
jhawkeye
May 25, 2022 06:33 PM
theshackle
Mar 5, 2017 06:37 PM
st.evel07
Aug 13, 2015 06:15 PM
ChevyZ71
Aug 13, 2015 07:30 AM
