440 + 727 trans can it be done?
Car: 1990 camaro rs
Engine: 305 tbi
has anyone considered this? I'm curious on how hard this would be to drop into my camaro, I have heard that big blocks in our cars can be tricky...how hard would this be and would it need a lot of mods?
Tim
Tim
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 440 + 727 trans can it be done?
A 440 isn't a big block, it's a Mopar engine. Nothing will fit readily, you'd have to fabricate everything. As with all exotic swaps, if you have to ask...
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Ape is right.... Its a mopar, which is a whole different animal from the GM engines.
When people talk about 'big block swaps' they are talking about GM big blocks... like the 427 or 454 Chevy engines, which have parts readily available to swap them in.
Car: 1990 camaro rs
Engine: 305 tbi
thought so just wondering if it'd be worth the swap even with gettin the setup for cheap...
Car: 1987 Trans Am
Engine: LQ9/L92
the money you're saving on the engine and trans will be completely overshadowed by the time and money you're going to spend on custom, one-off parts to try and make things worth. agreeing with everyone else on this one; not worth it
Car: 1990 camaro rs
Engine: 305 tbi
didn't think so but if it were to be done it would definably be unique! And thats what I always shoot for.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
With enough time, money, fabrication skills, tools, etc, any drivetrain swap can be done in any vehicle. If you want to do an exotic swap, that's up to you but don't expect a lot of help asking questions on how to do it. It's one of those things that if you want to do it, you go ahead and do it. If you screw up or decide it can't be done, then it's your own mistake for trying. If you succeed and it turns out well then you have something that nobody else has and can be proud of it.
Swapping in a BBC into a third gen isn't too difficult but it's a whole lot easier than dropping in an engine/tranny from a non GM vehicle.
The 440 is a pig anyway and the 727 is too lightweight. A Chrysler 383 with a 904 is a better combination.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
sorry, but it was the first thing to come to mind
yes it would be different, but being different at a absurd cost with little return is a bit of a waste in my book.
you can find used cheap chevy big blocks quite easily, and it will be a whole lot easier.
Car: 1990 camaro rs
Engine: 305 tbi
hmm haven't thought of that combo yet...and I know it can be done I was just wondering what others thought of the swap, it would be a challenge for sure
Car: 1983 firebird
Engine: 427 v8
Axle/Gears: 3.42 posi
it could be done if you want,motor mounts,trans cross member,drive shaft and exhaust will need to be custom made also you will need a larger rad as its a big block and will put out more heat than your 305 also different fuel system from your fuel injection to carb and then you got the engine wiring harness to go through to get rid of your fuel injection stuff if you live some where they do emissions checks your in for a lot more work to make it the same as your 305 spec's
now after all that if its a 440 for cheep chances its a smog motor and that means you might not get ant h.p increase as some of them had around 200 h.p.
then theirs the trans 727' take a lot of power to turn compared to a g.m trans i do not know why but all my mopar buddy's say the same thing and on top of that you will lose your over drive = less gas mileage taking away from the cheapness of the setup
my advice is to get a 350 and start there and if you want more that try a 383 or a 400 sbc's are cheaper to build and are way easier to swap in a third gen (it comes with one) and they are a good motor to build or you could find a good used setup for way less this swap will cost
hope this helps you and good luck with your camaro
Car: 1990 camaro rs
Engine: 305 tbi
no offense but nothing smaller than that 440 would be going into my camaro. In my opinion the 350 is wayy overdone, The real plan is for a 454 or if im lucky enough a 572, I know there some advantages to building small blocks and disadvantages to big blocks but I just rather have my car different. I appreciate the advice though
Car: 1978 Chevrolet impala
Engine: 350ci 300hp/356tq pace crate
Axle/Gears: 3.42 Yukon posi
I think you're a little too concerned with being radical, and not enjoying the drive :P
EDIT: Any big block swap will set you over 10g's easily. everything needs to be replaced. Trans, kmember, rear end...everything.
Not to mention building a BB that isn't a dog will cost you an arm and a leg in and of itself.
My 454/TH350 swap didn't cost me anywhere NEAR 10k.... maybe 3k, close to 4k tops. Its not a monster by any means, but its just as fast as the 400hp 350 it replaced, and its a whole lot more civilized on the street than that small block ever was (which was the goal in the first place).
Car: 1990 camaro rs
Engine: 305 tbi
Car: 1983 firebird
Engine: 427 v8
yea i know what you mean, no replacement for displacement, i will do a bbc swap in my firebird some day i actually like big blocks way better my self just saying there is better ways to go than a 440 in a third gen
i think a tbi 454 like early 90's 454-SS's had would be a really slick set up and with fuel injection it would have great street manners if you could tune it (not some thing i know a lot about on fuel injection)
i did not mean to insult you or your ideas big block are cool just trying to help you out
i wish you all the best luck with your big block
Car: 87 IROC L98
My 91 454SS is crap. The Gen V block is the worst BBC GM ever designed. The TBI system can max out to around 330 HP. You just can't flow enough fuel through the 2 injectors to support big numbers. The Gen V peanut port heads have no performance potential and they use a non adjustable valve train with 3/8" rocker studs meaning everything needs to be replaced if you want to put any kind of reasonable cam in the engine.
A 572 is a tall deck block. The swap will cost you a lot more than a normal short deck block. If you're going to go through all the expense of putting a tall deck block in, go right to a 632.
Stop watching the car shows on TV and reading about exotic swaps in the car magazines. Do a real world swap that's obtainable and affordable. If money isn't an object, you would never be asking if it can be done.
Engine: 383 Carb
Transmission: 4L60
DOnt know anything about big diesels, just wiki'd it and saw a 20 cylinder version :P
Car: 1990 camaro rs
Engine: 305 tbi
p.s. - where would you even get a 632? and now that I think of it doesnt that block have a nickname like avenger or warrior or somethin like that lol
Car: 87 IROC L98
572 = 4.500" bore and 4.500" stroke. Although that displacement can be obtained with different combinations, that's the most common. It's difficult to get a 4.500" stroke in a short deck block. The wrist pin is positioned too high into the ring lands.
A 632 is 4.600" bore and 4.750" stroke. A standard aftermarket 4.500" bore tall deck block is bored out and more stroke is added.
To get larger displacements than that, you need to get into the super tall deck blocks with wider bore spacing but there are bigger engines out there.
Car: 1990 camaro rs
Engine: 305 tbi
now what is the difference between a short and tall deck block? I assume one will sit higher than the other,like the difference between some truck engines and other motors?
Car: 87 IROC L98
It's the distance from the crank centerline to the deck surface. A tall deck block is 0.400" longer. The longer cylinders allow for longer strokes.
The heavy trucks (5 ton, school buses etc) got the tall deck blocks. The pistons were taller with an extra compression ring. Tall deck blocks need longer pushrods and use a different intake manifold or a short deck intake with spacers.
Factory tall deck engines were 366 and 427 CID (6L and 7L). The 366 has no performance potential. The bore is too small. The aftermarket has increased the bore and stroke for larger displacement but still retains the 0.400" deck height because of aftermarket parts availability. Even taller decks are available as special engines.
Car: 1988 rs
Engine: 555BBC; Dart, Lunati, SRP, Howards
Transmission: ATI TH-400
Axle/Gears: 35 spline 9", locker, 3.00's
It all boils down to budget. if you are looking for 500+ CID, you are looking at $2000+ for just the block (aftermarket). If you can get a good 427 tall deck OEM block, you are looking at a max of about 500 cid, and thats with a lot of grinding in the block for stroker clearance.
If you have never dealt with power like you will be getting with this many cubes, you also need to replace your whole driveline. i say get a mark IV 454, stroke it to a 496, HR cam, and a th-350 or 400. 500+ hp, and very streetable. still moderately expensive, but lots of reliable power.
Car: 55 210
Engine: 454
Transmission: Muncie
Axle/Gears: 4.56
Go for it ! These engines provide a HUGE amount of torque . Be sure the rest of the car can handle it ! Plenty of Aftermarket heads , intakes , cams , cranks etc. available as well . You can go as far as 632 " if you wish (with the appropriate crankshaft / piston combo ) .B/E- body headers will probably be a close fit and you can use a turbo 350 or 400 with a J.B. Racing Trans bell housing / adapter (complete bellhousing is bolted to the trans - takes care of starter flywheel/flexplate issues ) or stick with the tried and true 727 torqueFlite. The stock rear member in the 3rd Gens are incredibly week by Mopar standards so a Forb 9" or better yet an aluminum Dana 60 is the way to go.
Best of Luck with the swap !
B R
Now if you`d said Hemi !!!!! Thats a whole other deal !
B R
Car: 1988 Pontiac Firebird Base model
Engine: 5.0 V8 TBI
Transmission: Stock Auto
Axle/Gears: Stock
but why drop a Chrysler 383 in when you can build a Better and imensly more powerfull 383 out of a standard 350 SBC block and it still bolt right in eagle Makes a 383 stroker kit for $900 bolts right on to a 350 with some minor boreing, all said and done you will probbably come out on the cheaper and easier side doing a a 383 SBC than exotic swaping a chrysler in it
Engine: 5.0 V8 TBI
Axle/Gears: Stock
Car: 88 Rs Camaro
Engine: 1972 440 Magnum
Transmission: A-727
Axle/Gears: Curry ford 9 inch 4.39 gears posi
I have a 440 magnum with 60k original miles from a motor home with a heavy duty 727
all forged internals stock with 6 pack rods 906 heads and 11 to 1 comp picked up both for 300 put it in my 88 Camaro it fit really easy had to fab headders and mounts and a drive shaft it is a cool setup put 3 inch side pipes and a full rollcage and a sub frame all tied in again no problem if you like to fabricate. also put a curry ford 9 inch with 430 richmonds a grizzly posi and leaf springs with an adjustable pinion snubber nothing hangs below the original sub frames still have my 5 inch ground clearance for speed bumps I have had a 70 charger a 72 barracuda and a 70 duster all with the 440 and loved that motor combo have a thread going haven't posted in a while I will put some new pics up for you. By the way have less than 3 grand in the whole thing nice to see someone thinking out of the box
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
1992 Trans Am
May 10, 2023 07:19 PM
Hawk312
Aug 22, 2017 08:55 PM
Hello, Michael
Aug 20, 2015 03:19 PM
Well said sir :]
