Serpentine fitment issue.. Please read.
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
Stock, my 305 came with a 6" Harmonic balancer, sat 1/4" away from the timing cover..
My new 1978 350 has an 8" harmonic balancer, 1/2" away from the timing cover, and the balancer is actually thicker than the old one..
I know my serpentine setup is going to require spacers all around.. Now, I have no smog (Running headers, and edelbrock intake) so No EGR and no AIR to worry about, I'm running a carb so theres no computer to worry about.. I'm also going to be e-testing it as a Hot-rod, so big brother can eat me..
What options do I have here? I also have no A/C any more.. Would I be better off buying a V-belt kit? Or a small serpentine setup?
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Engine: 2004 LQ4
Re: Serpentine fitment issue.. Please read.
The front face of ALL SBC crank dampers is in the same location, except for the Vortec motors (because of the crank pos reluctor wheel). Even the ones from 265s and 283s, from before they even WERE dampers, but instead were only pulley flanges.
They are not all the same thickness however; the rear face of them varies.
NO belt setup requires spacers, if assembled fully and correctly.
Sounds like yours is not on all the way. That damper should almost be rubbing the TC.
You can use the 305 damper if you want, but the one you have is probably better.
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
And I was under the impression that all SBC balancers were either 6 in or 6 3/4 in, never heard of an 8in balancer .... but I'm no expert either.
There are actually SEVERAL sizes of them.
From my memory of dealing with them over the years, which may not be perfect:
The old 265/283 pulley flange was just that, a flange, not a damper (it had no inertia ring). It was about 4½-5" OD and about 3/8" thick; basically just thick enough for pulley bolts to bolt into.
The original 327 damper was about 6", and was only about 1" thick.
The 350 had 7" and 8" ones, which were about 1½" thick. The 400 one is the same as the 7" 350 one except that a chunk is missing from the damper ring.
Up to this point, all of them had the timing mark near 1:30. There are 2 versions of this timing mark however; the early version was about ¼" (6-8°) different from the FAR more common, later one. The following ones have the timing mark at 12:00.
The 305, and most of the later 350s, got the 6¾" one that's about 1¼" thick.
The Vortec one has a slightly shorter snout, to accommodate the reluctor wheel which is mounted on the crank between the damper neck and the timing gear.
On ALL of them, the face that the pulleys mount to, is the same distance from the front of the timing gear. The thickness differences are in the rearward direction. The 265/283 pulley flange was about 1", or a little more, from the TC; the largest ones come very close to the TC.
All pulley setups will work on all dampers.
Engine: 2004 LQ4
Then when I put the balancer bolt in, it moved maybe 1/8 of an inch and was really tight.
Ummmmm,,,, .... ,,,, OK.
Sounds great.
So what?
It's not on all the way.
Try using the right tools. A damper installer, available FOR FREE at many parts stores such as AutoZone or Advance, would be a great place to start. Try operating it with a socket or a box-end wrench.
Telling us here all about what you did to tighten it, won't scare it into jumping the rest of the way on.
I've noticed in my several accumulated weeks of wrenching on old cars as stress relief, the parts are COMPLETELY indifferent to sob stories. They only respond to action. Son, you just gotta get out there and do it.
Sounds great.
So what?
I've noticed in my several accumulated weeks of wrenching on old cars as stress relief, the parts are COMPLETELY indifferent to sob stories. They only respond to action. Son, you just gotta get out there and do it. Last edited by sofakingdom; Jan 12, 2011 at 08:37 PM.
Engine: 2004 LQ4
Sounds great.
So what?
Sounds great.
So what?
I've noticed in my several accumulated weeks of wrenching on old cars as stress relief, the parts are COMPLETELY indifferent to sob stories. They only respond to action. Son, you just gotta get out there and do it.Joined: Sep 2005
Then you don't have it on all the way.
Find out why it's not on all the way. Arguing with me isn't going to install it correctly.
Engine: 2004 LQ4
Got it in another 1/4" with my new 1/2" Dewalt 18V impact.. I'll do some measurement for the serp. When I get it in the car.
Chad Speier
Sep 24, 2015 12:32 PM
86White_T/A305
Sep 21, 2015 05:28 PM
