305 to L 98 I need advise
Old Jan 30, 2011 | 02:52 AM
ptrblt100's Avatar
Car: 87 IROC Z
Transmission: auto
Axle/Gears: 9 bolt posi
I have an 85 Trans Am I am thinking of changing over to a L98 out of a Corvette can some tell me if this is a easy swap? or should I persue a different power source?
More info on the engine I am looking to aquire it a 86 L98 with 52k with all wiring ecm it also comes with the 700R4 trans and it is the aluminium head model out of a vette. Will I be able to use the oil pan that it somes with and is there any kind of engine or motor mount issues?
Thank you for any helpful info.
Old Jan 30, 2011 | 09:23 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
I don't have personal experience with the Vette engines, but from what I understand, the oil pan will not work in a 3rd gen f-body. Since your 305 is an '85, and the Vette is an '86, you have different rear main seal types, which I believe means the pans won't swap. You shouldn't have trouble finding a pan and oil pump/pickup that fits the 350 and your chassis, though.
Old Feb 3, 2011 | 06:30 PM
ptrblt100's Avatar
Car: 87 IROC Z
Transmission: auto
Re: 305 to L 98 I need advise
Thank You for the response but after further reading I have decided to go with a 6L LS 2.
db057
Apr 28, 2019 07:45 AM
buffaloman
Firebirds Wanted
Sep 7, 2015 09:47 AM
buffaloman
Camaros Wanted
Sep 7, 2015 09:46 AM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
Formula_88AE
Sep 3, 2015 01:47 PM
