350 swap
Old Jan 31, 2011 | 11:44 PM
ericg83z28's Avatar
350 swap
hi guys i got an 350 sbc goin into the 83 z28 with the 5speed , is it easier installing it without the trans , or is it easier with the trans attached?
Old Feb 1, 2011 | 12:03 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 350 swap
Some people find it easier one way, some people the other.
Old Feb 3, 2011 | 09:27 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: 350 swap
i found it easier to install the motor by itself, only because I can be a bit clumsy and less likely to break stuff (like wiper motor). with an engine leveler and an extra set of hands, you may prefer to do both together
Old Feb 3, 2011 | 01:11 PM
ericg83z28's Avatar
Re: 350 swap
any tips to make it a really easy install cuz its a 5spd
Old Feb 3, 2011 | 03:06 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: 350 swap
I take engine and tranny out together. I use a one ton hoist though which requires me to take the front bumper off. If you have a long hoist and or a forklift you could do both without removing the front bumper. Many people keep the engine and tranny connected because the tranny bolts are hard to get to in the car.
Old Feb 3, 2011 | 03:07 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I would say if you pull the engine alone, you should drop the transmission from the bottom first. Trying to stab a manual tranny input shaft into the clutch disk while the transmission is in the car and the engine is suspended by a cherry picker is a recipe for frustration (if not disaster).
I wouldn't drop the tranny without either a pretty strong friend, or a transmission jack.
I haven't had any trouble pulling or stabbing engine and transmission together (did do engine-only once - with auto tranny). It should be easier with a manual.
xkingcodex
Feb 12, 2020 07:43 PM
bellez77
Sep 5, 2015 08:39 PM
theshackle
Aug 22, 2015 06:52 PM
armybyrd
Aug 10, 2015 09:23 PM
gwade12
Aug 8, 2015 08:17 AM
