WHERE IS GOOD PLACE TO HOOK UP TO TO L98 5.7 ???
Old Feb 4, 2011 | 01:43 AM
DRIVE2FAST's Avatar
Car: 90 IROC 5.7 1LE CLONE 89 GTA 88IROC
Engine: 5.7TPI / 5.7TPI/ 5.7TPI/ 4.3 CMFI
Transmission: 700R4 UPGRADED 700R4STOCK700R4STOCK
Axle/Gears: 3.23 10 BOLT 3.27 9 BOLT 2.77 9BOLT
FOUND LIFTING EYE IN BACK OF 88 L98 5.7 TPI. DONT SEE ANY OTHER SOLID ATTACH POINTS.....SPECIAL BRACKET/ADAPTER TO PULL ENGINE ? ????? I PLAN TO USE THE ALUMINIUM R/H ACCESSORY BRACKETS WITHOUT AIR PUMP / A/C COMPRESSOR AND L/H SIDE ALTRNTR / PWR STEERING BRACKET. LOOP SOME CHAINS THRU FOR 3 POINT HOOKUP TO LOAD LEVELER AND PULL IT.SO FAR SO GOOD.
Old Feb 4, 2011 | 01:32 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: WHERE IS GOOD PLACE TO HOOK UP TO TO L98 5.7 ???
I'm not clear on what you're asking here...?
Old Feb 4, 2011 | 02:14 PM
DRIVE2FAST's Avatar
I WAS LOOKING FOR SOLID LOCATIONS TO HOOK UP TO THE ENGINE TO PULL IT. MINE HAS ONLY ONE LIFTING EYE IN THE BAK.
Old Feb 4, 2011 | 03:44 PM
Sonymaster20's Avatar
Car: 1992 Rs
Engine: 305 TBI
Transmission: 5-Speed
Axle/Gears: 3.08
You could go to an auto parts store and get an engine hoist bracket that bolts to where the carb/Tpi mounts up to? you would have to take the Tpi off though
Old Feb 4, 2011 | 05:38 PM
DRIVE2FAST's Avatar
YEAH THATS WHAT I FIGURED. IM GONNA USE THE ALUMINUM LEFT AND RIGHT ACCESSORY BRACKETS THAT CAME WITH THE ENGINE AND THE REAR LIFTING EYE. SHORTCUT TIME.
Old Feb 4, 2011 | 09:24 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
I usually just stick a bolt through the chain and bolt it onto the front of the head.
Old Feb 4, 2011 | 10:58 PM
DRIVE2FAST's Avatar
EVEN BETTER SHORTCUT. NOW I NEED TO HIRE A BUNCH OF MONKEYS TO KLEAN OFF ALL THESE SLUDGED UP PARTS....
Infested
May 22, 2018 11:56 PM
TheExaminer
Aug 19, 2015 10:07 PM
jharrison5
Aug 19, 2015 05:53 PM
matthew911
Aug 12, 2015 09:38 AM
