Timing Chain question
Car: 85 iroc
Engine: 383
I cant seem to find a double roller chain for a roller block. Could someone tell me where to find one.Thanks.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Timing Chain question
Where have you looked? Every manufacturer has one... try Comp Cams 2136.
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Aren't the roller blocks like 1988 & up? Wouldn't any double chain listed anywhere for say a 1992 Camaro be appropriate? If so, just about every auto parts store has one.
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
Roller blocks are 1987 and up.
Car: 1992 RS
Engine: Carbed 350
I'm lost - are we looking for chains or gears? Or both?
Billet? They are hidden under a cover, and drowned in oil - who cares what it looks like, as long as it's strong enough to do the trick?
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
From summit
http://www.summitracing.com/parts/CCA-2100/
http://www.summitracing.com/parts/EDL-7800/
http://www.summitracing.com/parts/CLO-C-3023X/
These are three of many double roller TC's that are available
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
Look at the applications of those double roller chains. It says Will not work with factory roller cam.
Factory roller cams have a thrust plate that takes up space. search Summit and you can find a AC Delco single roller for factory roller cams.
Is the OP working with a factory roller motor because his 85 was not a factory roller so we should know he is not working with a stock motor.
Car: 1992 RS
Engine: Carbed 350
These don't have the roller block disclaimer:
http://www.summitracing.com/parts/CLO-9-131/
http://www.summitracing.com/parts/CLO-9-145/
http://www.summitracing.com/parts/EDL-7844/
http://www.summitracing.com/parts/CLO-9-130-10/
I just used the Summit search for "timing chain" and then narrowed results for Chevy, V8, Double Roller, and 1991 engine (which should be roller).
I know I bought one from my local CarQuest several years ago for my 1990 TBI motor (which is a roller block) right off the shelf.
Car: 85 iroc
Engine: 383
Both. And I agree.. they are hidden, but I have a billet cam and a two piece billet cover so might as well just buy the billet gears also. If you knew what kind of person I was you would understand that Im a nit-pick-f$#!, it sucks but I cant help it. As for the motor its a summit 383 roller block going in a 85 iroc.
Car: 1992 RS
Engine: Carbed 350
Oh - I understand the nit pick - I myself am as **** as my wallet allows, and trust me, my wallet allows more **** with my car than anything else. I'll gladly (and have before) eat bologna sandwiches for every meal for a month if it means getting enough cash scraped up for the part that I want.
Kids are hungry? Nonsense, they ate once today at school!
DADDY NEEDS CAR PARTS DAMMIT!
Car: 85 iroc
Engine: 383
Car: 1988 IROC
Transmission: 700R4 Silver Dart
Axle/Gears: 3.70 posi
The EDL 7801 Edelbrock by Cloyes is for roller cam blocks, double roller.
http://shop.advanceautoparts.com/web...010_9961152___
