305 What to do???
Old Feb 16, 2011 | 10:37 PM
91frankincamaro's Avatar
Car: 1991 rs B4C package
Engine: 1972 355 sbc
Axle/Gears: 10bolt 3.73 gears
305 What to do???
hey the 305 in my 1991 camaro is seized up. was wondering what i should do for a budget build, removing the motor as we speak so i can tell how much damage was done. thinking bout boring it out. any ideas????
im 17 so this is kinda a budget build so nothing too crazy
Old Feb 17, 2011 | 10:59 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: 305 What to do???
You should 'budget build' a method of transporting it to the yard and sell it for scrap.
Seriously - I'd consider looking at craigslist for a used 350 to replace it - for what the machine work, new pistons/rings, etc. will cost you, you could get a complete used 350.
What county in NC are you in?
Is this a TPI or TBI car?
Old Feb 17, 2011 | 11:07 AM
im in pender county. and i have a guy that will do the machining really cheap he is a friend of the family thats why i was going to reuse the block and its TBI with the quadrajet (quadrajunk)
Old Feb 17, 2011 | 04:22 PM
Car: 1992 RS
Engine: Carbed 350
OK - given the friend, might not be too bad then.
And it's just a TBI car, not Quadrajet - the Quadrajet is a carb, the TBI is a Throttle Body - not the same thing at all.
Even if it was cheap - the same machine buddy ought to have a line on a good used 350 motor for cheap - you can keep the TBI and swap in a chip from a 350 TBI car (Caprice or truck), and swap in 350 injectors and 350 knock sensor and be set. Guess it all depends if you just want it to run, or run better/faster. Also, I don't think Pender county requires emissions - you could swap to carb as well, but would be more expense.
Old Feb 17, 2011 | 04:44 PM
AmorgetRS's Avatar
Listen to camaronewbie, he speaks the truth.
pjsparts
Oct 29, 2025 06:39 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
rsrookie
Sep 5, 2015 07:08 PM
Formula_88AE
Sep 3, 2015 01:47 PM
