TPI to vette motor Part 2
Car: 1990 GTA
Engine: 355
Is my 1990 350 TPI a Direct bolt on to a 1990 vette motor? Is the exhaust ports different because they are aluminum heads? Will my EGR work? Thanks!
Re: TPI to vette motor Part 2
Bolt-on, yes; except the center 2 blot holes on each side of the intake will need to be slotted because the 113 casting uses the 86-back bolt angle.
Exhaust, yes.
EGR, no. The 113 casting has no exhaust crossover passage.
Exhaust, yes.
Sanjay
Aug 12, 2015 03:41 PM
