305 build up or just swap for a 350? dont know what to do!
Car: 1990 Camaro RS
Engine: L03 305 TBI
i have been doing some research this week to decide what type of mod i am going to put in my 305. i just finished saving up my money and enough money for quite a few mods if i wanted to. but i always here people saying just put in a 350, but i can add stuff to my engine such as headers, exhaust, heads, cam, intake, ignition, and more that would definitely get my HP up and even putting in a chip i can get 25% more HP. so do i do all the modifications or put in a 350, because couldn't i do enough mods to get my 305 as much HP as a 350? but i sounds like a 350 would be more expensive? i dont know what to do?!
Car: 88 camaro irocz
Engine: l98 tpi
Axle/Gears: 2.77
Re: 305 build up or just swap for a 350? dont know what to do!
you can mod a 305 to about 350 crank horsepower n/a then throw a turbo or power adder of your choice for another 100-200 hp . it all depends on what you want ...
Car: 1990 Camaro RS
Engine: L03 305 TBI
that's what im sayin, i really dont know, but i think i would wanna get 300 HP or more out of my 305. but i was planning on putting in a few mods but all roads lead back to me just putting in a 350. would it be more fuel efficient to go with some mods and then a turbo compared to a 350. and what are the cost of some good turbo?
Engine: l98 tpi
Axle/Gears: 2.77
a 350 or 355 or 383 may be cheaper but i like being the underdog an the 305 is that lol . plus as far as i know i'll have the only turbo'd third gen. in my area .lol
Car: 1990 Camaro RS
Engine: L03 305 TBI
thats my plan actually , i'm gonna put vortec heads a lt1 cam i'm gonna get the dynamic efi computer to tune with add headers then once thats all tuned to the max i got a turbo in the basement i'm gonna add to the mix i'm wanting low 12's out of mine ...
thats why i hesitant to swap in a 350 b/c if i keep my 305 and build it up, it will be a sleeper, and i want to be able to smoke guys that got a 350.
so your saying a 350 would be cheaper, but would you get more power from the 350 compared to the built 305? and even without turbo, putting in all those mods, would that be a waste of money? and have you done any mods to your 305 yet?
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Second, there is a lot involved in putting a turbo on. You dont just bolt it up and thats it.
Third, if you want lots of power, dont worry about gas mileage. I'm lucky. My engine makes probably around 450 or so horse and I can average about 15 mpg city if I drive easy.
Fourth, price is very hard to estimate. You could either one cheap or drop a ton of cash on either one. As a general rule though, to get the same power out of a 305 instead of a 350 will cost more.
Engine: l98 tpi
Axle/Gears: 2.77
mod for mod a 350 will be a stronger engine jus cause it has more cubic inches . i have headers an the lt1 cam an the tuirbo stuff in the basement . i haven't done anything yet i jus been buying parts . my build hinges on the computer i can tune it all with . i'm gonna get that soon hopefully an figure out how to tune it on a stock motor first then hopefully i'll have the parts for the top end . i'm in no hurry myself i figure by the fall of this year i'll have it all done .mine is an everyday day driver so i have to plan my build in small sections .lol
Engine: l98 tpi
Axle/Gears: 2.77
lucky for me i have turbo experience jus have to learn the computer i'm buying but rbob offers lots of support so i'm not worried about that either .lol
Car: 1990 Camaro RS
Engine: L03 305 TBI
First off, just because you have a built up 305 doesnt mean you will smoke every guy with a 350. If you think thats the case, I'll race you.
but basically your saying that to get the 350 power out of a 305 it would be more expensive, and im just better off dropping in a 350 then do some mods to the 350, right?
What I was really trying to say was that, what is your definition of 350 power? My brothers 95 C1500 came with a 350 stock making 210 horse. My 350 is make around 450. There is no set amount of power a 350 makes. Even in stock form some are more powerful than others.
Even if you build up a 305 (unless its very built and under boost), I wouldnt sweat racing you. The 305 has some limiting factors based on the bore vs. stroke ratio that limit its abilitly to make good power, unlike the Ford 5.0
If your just wanting 300 horse, a very mild built 350 would be the way I would go. If you want that out of a 305, your going to need good heads. You can get 300 horse out of a 350 with stock heads that are just cleaned up.
Car: 1990 Camaro RS
Engine: L03 305 TBI
Car: 1990 Camaro RS
Engine: L03 305 TBI
and for right now until i get a 350, im probably just going to work on the looks of my car, rims, hood, interior, etc...
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Car: 92RS
Engine: 305= boat anchor
Axle/Gears: 4th gen 3.23
I'd go with a 350, 305s are only good as boat anchors. I plan on doing a 350 swap as soon as I can save enough money.
Car: 1985 Trans AM
Engine: 350 ATK Performance
Axle/Gears: Eaton 3.73
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
The chip programming is what you need to consider before making a decision. If you don't know how, can't afford the time with car not running for weeks/months to learn, and don't have faith in anyone to do it for you locally (I say locally because through the mail, it'll take forever), then you need to pass on modding a 305 TBI.
The issue comes in with the TBI chip having limited capabilities, and bery few folks anywhere that even program TPI chips let alone TBI chips. There's a very fine line with TBI mods before you cross the line into custom programming land. You can do exhaust, small cam like a LT1 cam, maybe better intake - but touch the heads and you've crossed the line, and the TBI heads are the biggest restriction.
Now, a possible option would be a 350 TBI - not hard to do. You need the 350 motor, a 350 TBI prom chip from a truck or Caprice that had a 350 TBI in it, a 350 TBI knock sensor, and 350 TBI injectors - that is a realistic possibility MAYBE - I see you are in Cali, so your inspections process really screws you on much of anything since you have to replace your engine with one at least as new.
I suggest moving
I suggest moving
Car: 1990 Camaro RS
Engine: L03 305 TBI
Car: 1990 Camaro RS
Engine: L03 305 TBI
I suggest moving
I suggest moving
and plus, wont getting a 350 TBI w/ all the other required parts cost more than building up my 305?
Engine: l98 tpi
Axle/Gears: 2.77
I suggest moving
I suggest moving
Car: 91 Trans am
I suggest moving
I suggest moving
Transmission: 4L80E/4L80E
Being in California, can we assume you need to go through smog inspection and test? If so, that will be your #1 issue. For instance, is that Dynamic EFI C.A.R.B. approved?
It can be argued that for a relatively small budget, you can end up with more power out of the 305 than you could swapping in a 350. The reasons for that are, anything you spend on the 305 you'd also have to spend on the 350, and most likely the 350 will need a rebuild on top of that.
But, the more money you spend, the less that will be true, and at some point the 350 will make a lot more power than the 305 can.
Understand that Vortec heads do not have the exhaust crossover passage that your 3rd gen heads use to feed the EGR valve. If you have to pass smog inspection/test, you need a functioning EGR vale.
Car: 1990 Camaro RS
Engine: L03 305 TBI
http://sfbay.craigslist.org/eby/pts/2273038381.html
what else would i need to swap it in to my car, and im no engine expert, but is there a way you can tell if there is something wrong with it before purchasing it?
You can do a compression check to see if it has good compression that is even across all of the cylinders.
You would need a transmission (obviously - trying to use your current transmission would not be a good idea), a fuel tank from a 4th gen LS1 f-body (which causes problems with the fuel gauge), aftermarket swap engine and transmission mounts, and would need to do some rewiring and have some exhaust work done. Doesn't look like he's including exhaust manifolds, so you'd have to find them or use emissions-legal headers.
Car: 1990 Camaro RS
Engine: L03 305 TBI
http://sfbay.craigslist.org/eby/pts/2273043525.html
Sanjay
Aug 12, 2015 03:41 PM
