remove vats and ecm for tpi to carb swap
Old Mar 26, 2011 | 09:39 AM
adams92z's Avatar
I am building a 350 with carb to replace a bad 5.7 tpi that is in 1992 z28. I will be dropping the tank to remove the fue pump and will have a mechanical pump on new build. I will also have a distributor with vac. I am trying to make it work without computer or ecm. Before I started removing the engine i noticed that the key will not turn the starter (no click or anything). I have power to everything else. I want to know how to how to do awsy with the vats and ecm. I do not want to use the resistor trick on the wires on the column. I want to do away with vats all together. Thanks for any help
Old Mar 26, 2011 | 06:02 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
There are a couple of tech articles linked from the thirdgen.org homepage that discuss VATS. You should be able to figure out from that what you have to jumper to bypass it.
Old Mar 26, 2011 | 07:56 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: remove vats and ecm for tpi to carb swap
All you have to do is ground the black wire from the starter enable relay, located in the driver side footwell, usually up in where the fuse box or hood release latch is - the relay will have a large yellow wire from the ignition switch (located on top of the steering column under the gauges kind of), and have a large dark green wire running out to the neutral safety switch, along with a small black wire that comes from the VATS module - just cut the black wire and permanently ground it anywhere.
Old Mar 26, 2011 | 09:33 PM
adams92z's Avatar
When I cut the wire, do I ground both sides or just one and which one. Thanks for your help, I knew there was a way.
Old Mar 26, 2011 | 09:55 PM
Car: 1992 RS
Engine: Carbed 350
Wire comes from relay to VATS module - leave as much as you can connected to the relay, cut it, and ground it for the relay - don't need anything on the VATS module side, just let it hang.
Frozer!!!
Jan 19, 2024 04:55 PM
Jae992
Aug 27, 2015 09:07 AM
NBrehm
Aug 25, 2015 11:49 PM
djmarch
Aug 9, 2015 05:27 PM
3rdgenparts
Aug 8, 2015 07:09 PM
