swaping my new motor in what do i need
Old Apr 22, 2011 | 01:39 AM
91maroRS91's Avatar
Car: 1991 Camaro RS, 1987 Firebird
Engine: 305 TBI, 350 TPI
Transmission: 5 Speed, Auto
Axle/Gears: N/A someoone tell me
my motor is taking a **** on me getting oil in the air filter and the valves are tapping. by the way its a 1991 camaro rs with a 305 tbi and 5 speed. this is my first swap and woundering what gaskets and what not ill need . im putting in a 89 305 tbi in guessing alot of the sensors and what not will be in the same place. im going to just unhook from the trans and just pull the motor out. what gaskets should i look at replacing.
Old Apr 22, 2011 | 02:35 AM
91maroRS91's Avatar
Re: swaping my new motor in what do i need
also will i have to adjust the timing at all on the motor im putting in
Old Apr 22, 2011 | 10:09 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
If you aren't taking off the intake manifold or water pump to change from engine to engine, you shouldn't need any gaskets.
Typically the distributor gets in the way when pulling the engine, so it is removed to protect it. You will then need to set the timing when you get the "new" engine running.
If the '89 is from an automatic, you will need a pilot bearing/bushing to put into it before you install your flywheel & clutch.
hydrolic144
Sep 8, 2015 06:55 PM
greenyone
Aug 29, 2015 11:08 AM
Randomtask2
Aug 26, 2015 03:34 PM
madsv1000
Aug 20, 2015 06:45 AM
slade5612
Aug 11, 2015 07:19 PM
