8.1L (496ci) Chevy Vortec swap?
Old Apr 22, 2011 | 11:53 AM
sk8r fer life's Avatar
Car: 1990 camaro rs
Engine: 305 tbi
Anyone considered this before? I don't think Ive seen a swap with this motor before, i wouldn't think that it would be the easiest swap but would it be worth it if you could get the engine for the right price?
Thanks Tim
Old Apr 22, 2011 | 01:35 PM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
Re: 8.1L (496ci) Chevy Vortec swap?
It would work but you would need the trans to go behind it. At least the 4l80e. You would have to do some serious floor surgery to get it to fit the trans and you would probably have to have a custom crossmember made to make it work. Anything is possible if you have the time and money. Personally, I wouldn't waste my time on it since you can build an extremely stout LS motor for alot less headache.
Old Apr 22, 2011 | 02:59 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
It's basically a BBC swap with several complicating factors.
The accessories and intake sit pretty high. You'll have fun fitting a hood over it all. Mark IV and Gen V & VI stuff doesn't fit them, so there isn't much aftermarket support. I believe it is also a tall deck, so custom exhaust will be in order.
In 2004 when I took the '57 to Pomona (from Colorado), a co-worker offered his 2003 31' coach to tow it there (and stay in on the way and while there) - as long as I took him along. It pulled that car & trailer over the mountain passes like nobody's business, and averaged 7 mpg in the process. It's a great engine for the purpose for which it was built.
I would say "worth it" is a non-stationary target. Personally, I'd go for an LS7 first (http://sdparts.com/category/gm-perfo...5hp-ls7-engine ). Or a standard deck BBC.
But, to each his own.
Old Apr 22, 2011 | 07:19 PM
Car: 1990 camaro rs
Engine: 305 tbi
Thats what I was assumed, I'm not thinking of doing of the swap just curious if anyone else had. It seems like you said to be a ton of work, wouldn't it get better gas mileage though? seeing that it would be in a lighter vehicle. (if it were done that is)
Old Apr 23, 2011 | 01:10 AM
ATX-Iroc's Avatar
Car: 87 Iroc-Z
Engine: 305 tpi
Transmission: 700-r4
the 4l80e fits fine no surgery needed just a little dimple for the fluid line.
Old Feb 19, 2013 | 05:10 PM
Mayt13's Avatar
Car: 1989 Chevy Camaro IROC Z28
Axle/Gears: Stock
Honestly I'm thinking about doing this because my exaust needs to be re-run anyway and my cross member is dented and my hood needs to be replaced. I'm just wondering, Is there a MT I could use with this engine, I'd rather die than run an auto.
Old Feb 21, 2013 | 09:34 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Bolting up a T56 would be easy enough. Just use the flywheel for an '01-up C3500 with the ZF S6-650. You're on your own for figuring out which clutch, and getting it bolted to that flywheel.
xkingcodex
Feb 12, 2020 07:43 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Fast355
Dec 2, 2016 06:33 PM
theshackle
Aug 22, 2015 06:52 PM
jharrison5
Aug 19, 2015 05:53 PM
