Motor Mount Questions
Car: 1987 Firebird Aftermarket Trans Am
Engine: 5.7 V8
I read the engine swap thread before posting this, but I need a few more specifics. I have a '72 350 that I plan on dropping in within the month. I need motor mounts but don't know if I should get the engine swap mounts with the adapter plate or if OEM mounts will work. I'm assuming that just getting OEM engine mounts (not the frame mounts) will still line up with the mounts on the K member. If I don't need an adapter plate that'd be awesome.
NBrehm
Aug 5, 2015 07:57 PM
