Engine swap in California
Old May 20, 2011 | 12:42 AM
Jt41z4nZ28's Avatar
Ok so i dont need to change my engine. But i was thinking that one day i would swap for maybe an ls1 or zl6 but im not sure how that would effect smogging the car. If anyone knows smog laws in california pertaining to engine swaps i would appreciate it if you could share. Thanks for reading
Old May 20, 2011 | 09:26 AM
Guest
Guest
Posts: n/a
Re: Engine swap in California
The only guaranteed legal option is to buy a complete '98-'02 Z28 / Formula / Trans Am donor, probably totalled, and swap everything over. The Y-pipe won't fit, that'll require a bit of work.
From there, any parts that are Cali-legal for your donor will be legal for you.
Now, what you can get away with is slightly different. Want to use an LS3? That can be done. Want to use a 224-114 cam? That can pass, too. And there's too much to list, really.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
