HELP WONT TURN OVER
Old May 18, 2011 | 03:38 PM
Maroman655's Avatar
HELP WONT TURN OVER
Ok got motor in all is good wired everything back up thing wont engage the starter purple gos to selenoid anything else im missing and yes i have the bat hooked up
Old May 18, 2011 | 07:50 PM
Maroman655's Avatar
Re: HELP WONT TURN OVER
is there something wrong i dont think the vats security thing is broke i did take out the ecm but i just jumped the selenoid and it popped right off do i have to bypass?
Old May 18, 2011 | 07:56 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
If you took the ECM out, the VATS won't allow the car to start.
Check the tech articles linked from the thirdgen.org homepage. You can also on the topic.
Old May 18, 2011 | 09:01 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Is the starter turning, or is the starter turning but car not running? Everyone states a car won't start or turn over, and I'm always confused.
Old May 19, 2011 | 11:26 AM
Maroman655's Avatar
so do the resistor thing and it should work?
Old May 19, 2011 | 04:15 PM
91phoenix's Avatar
Car: 91 Firebird,00 c2500,75 Vette
Engine: 3.1 but 350 soon, 350, 350
Transmission: T56 soon
Axle/Gears: stock 3.42 Posi to come
If the starter relay behind the driver kick panel is bypassed then it should crank. But clarify for us what motor before carbed or TBI or TPI or CFI and what do do have now. I would assume carbed as you said you took the ecm out.
Old May 19, 2011 | 06:24 PM
five7kid's Avatar
I'm no VATS 'spert, but as I understand it, without the ECM the VATS system cannot work. You need to totally bypass it, not just the resistor.
Old May 20, 2011 | 10:04 PM
Maroman655's Avatar
I got the vats system out or bypassed what a junk idea GM and i got the car out on the road sweet ride 4 day swap not to shabby!! I should of went with the th350 trans 700r4 seems a little slippy i guess the word for it, unless u guys know any quick fixes bigger stall converter? shift kit? motors pushing 380hp when i had it built? to much for the tranny?
gta892000
Aug 11, 2019 11:16 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
bbsr72
Sep 27, 2015 05:55 AM
greenyone
Sep 8, 2015 08:41 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
