Can't rev pst 2.5k rpms
Old May 25, 2011 | 04:17 PM
Firebirda7x's Avatar
Car: 1986 Firebird Trans Am
Engine: Chevy 355
Transmission: Built 700R4
Axle/Gears: 9 bolt 2.77
I'm in the process of dropping my fuel tank today to remove my electric fuel pump, right now the carb is sucking from a bottle.
The issue is that I can't rev past 2.5k rpms, and engine doesn't shift. I adjusted the detent cable, but that didn't seem to affect anything at all. In Neutral it will rev happily. Also, I have a horrendously loud whining belt-style noise. Gets louder as I rev. It is so bad it overpowers my 350. My 305 sounded a lot louder than the 350 did...more burbly too.
This is driving me nuts....
Old May 25, 2011 | 05:04 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: Can't rev pst 2.5k rpms
Where is the "belt-style" noise coming from?
Old May 25, 2011 | 05:17 PM
Engine: Chevy 355
Can't tell, it's equally loud from the whole engine bay. Can't tell if its from the water pump or power steering....it's a horrendously loud squeaky belt noise. My instructor says he thinks it's tranny related or power steering pump. Not sure if this is related to my tranny issue but I figured I'd toss it in there.
Old May 25, 2011 | 05:43 PM
plasmeh's Avatar
Car: 1986 IROC-Z
Engine: 360cu @ 10.5:1
Transmission: T56 - Pro 5.0
Axle/Gears: 4.10 - Zexel Torsen - Moser Axles
Gasket leak at base of carb? Makes a loud whistling sound when that happens. Have you tried shifting manually through the gears to see if it will rev beyond 2.5k rpms? Buddy has a nova with the same issue - it won't go past 2500 in drive, but if he rows it through the gears it will rev out.
Old May 25, 2011 | 06:23 PM
Engine: Chevy 355
This whole engine and all accessories were working on the previous car.
Old May 25, 2011 | 07:25 PM
Engine: Chevy 355
Oh, dunno if this is important but atm while I'm removing the gas tank to remove fuel pump (not going as bad as I thought) I have the fuel line running off a bottle under the hood. Timing has been set by ear as well until I get a permanent fuel setup.
gta892000
Aug 11, 2019 11:16 AM
wisemanz28
Sep 20, 2015 01:26 PM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
