350ci to a 400ci
Old May 27, 2011 | 10:14 AM
7thdarkangel's Avatar
Car: 1983 Camaro
Engine: Missing
Transmission: Missing
Axle/Gears: 9" Ford
350ci to a 400ci
im looking to swap out the carbed 350ci out with a 400ci block im picking up. i plan on rebuilding the 400ci before it goes into the car. any suggestions on parts, part variables or anything for that matter. (especially with the cam. Im not that good at picking them out.)
i was thinking about putting a full 4" stroke in it.
let me know whats up.
Old May 27, 2011 | 10:41 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 350ci to a 400ci
Make sure it's drilled for both starter bolt patterns.
Old May 27, 2011 | 10:47 AM
Car: 1983 Camaro
Engine: Missing
Axle/Gears: 9" Ford
Any reason than to be able to interchange?
Old May 27, 2011 | 10:50 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Various clearance issues can arise down the road when you try to use a 168 tooth flywheel and starter. Best to use the 153, and then everything fits just like it did when it was stock.
Old May 27, 2011 | 10:57 AM
Car: 1983 Camaro
Engine: Missing
Axle/Gears: 9" Ford
Ok thank ill add that to my long things to do if not already done.
Old May 28, 2011 | 03:38 PM
Car: 1983 Camaro
Engine: Missing
Axle/Gears: 9" Ford
got the engine yesterday.
Attached Thumbnails 350ci to a 400ci-img_0183-1-.jpg   350ci to a 400ci-img_0181-1-.jpg   350ci to a 400ci-img_0182-1-.jpg
1986Z28OWNER
Dec 13, 2015 10:19 PM
machinist21
Sep 5, 2015 03:03 PM
Dark_Boba
Aug 15, 2001 11:28 AM
Christos
Jul 15, 2001 04:25 PM
