rebuilt 350
Car: 1988 camaro
Engine: 305 tbi
Transmission: 700r
Axle/Gears: 3.73 posi
rebuilt 350
I have a question about a rebuilt 350 i have.the motor is now on the floor and i have a intake manifold and balancer on it withe the heads and pan.i was attaching my 700r4 to it with my new 2200 stall torque converter.While turning the motor to put on the converter bolts,I noticed the engine would not completly turn,it justed stopped.Turned the motor the other way and it stops at a certian point also.I was able to put the converter bolts on ok.The spark plugs are out.I am not sure if this is a problem or not.Any help would be great.
Re: rebuilt 350
Transmission: 4L80E/4L80E
This certainly is a problem that you want to get resolved now, before you try to turn the engine over with the starter.
I've seen things dropped down an open intake port that happened to have that valve open with the engine in the position it is in, then jam the piston when the engine turned over.
Find out what's making the engine stop. Do whatever it takes to find it.
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
509 camaro fan
Sep 6, 2015 10:43 AM
backtothe80s
Sep 5, 2015 12:39 AM
Eric-86sc
Aug 24, 2015 09:01 PM
