Bad Oil Leak (305)
Old Jul 2, 2011 | 01:01 PM
NathanLewis's Avatar
Car: 85 camaro z28
Engine: 355
Transmission: t-5
Bad Oil Leak (305)
I have this bastard of a leak happening on my 305. Its leaking on the passenger side and dripping down on the exhaust pipe causing smoke. The leaking only happens when you run the car, and my first place to look was the valve cover gaskets. So I pryed the old ones off, and replaced them with new rubber gaskets. No fix.
I don't think the head gasket could be leaking, that doesn't seem likely.
The oil seems to splash everything on the bottom including the transmission and the catalytic. It even goes a little higher than the where heads are. Its like its just spitting it everywhere. I can't find the leak....and I need this engine to hold out until I complete the new one.
Old Jul 2, 2011 | 01:59 PM
383 Power's Avatar
Car: 1982 SC/1984 Z28
Engine: 305 4BBL/305 4BBL H.O.
Transmission: 700R4/700R4
Axle/Gears: 4th Gen 3.23 Posi/3.73 10 Bolt
Re: Bad Oil Leak (305)
Did you check your Intake Manifold Seal?
Old Jul 2, 2011 | 02:15 PM
Car: 85 camaro z28
Engine: 355
Transmission: t-5
Ok, I feel like a total idiot. The dipstick is missing. As in, the entire tubing and dipstick is literally gone. I can't believe I didn't see this. I just ran the advanced auto parts and got another one, but I can't see where it is supposed to go. Does it go into the block or the oil pan? The Exhaust manifold is in my way...
Old Jul 2, 2011 | 02:30 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
in the block right above the oil pan.
Old Jul 2, 2011 | 03:03 PM
Car: 85 camaro z28
Engine: 355
Transmission: t-5
I don't even see the hole. I crawled under there and saw nothing..
Old Jul 3, 2011 | 02:26 AM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Just aft of the knock sensor and hidden by the starter.
Mine is aftermarket, but shows the location in the block for the tube.
Old Jul 3, 2011 | 09:25 AM
Car: 85 camaro z28
Engine: 355
Transmission: t-5
you are a lifesaver. Do I need to take the starter off to see it?
Old Jul 3, 2011 | 11:17 AM
Car: 85 camaro z28
Engine: 355
Transmission: t-5
Alright guys I finally got the dipstick in. I just used my bare hands to feel around under there and felt the hole. Problem fixed! Hah now I just gotta worry about getting the oil and sludge off my hands.
Old Jul 3, 2011 | 11:22 AM
travis401's Avatar
Car: 91 Camaro RS
dawn dish soap works wonders on oily hands
Old Jul 3, 2011 | 11:51 AM
Car: 85 camaro z28
Engine: 355
Transmission: t-5
Exactly what I used hah!
Old Sep 19, 2011 | 10:53 PM
brandon lee's Avatar
Car: 87 IRoc Z
Engine: 350 tune port L9
alright i have a 87 iroc l98 and i have a oil leak i put the car up on blocks to try to find it and had dad to give some gas to try to see if i can see where it is leaking from i had the torque converter dust cover off but i did not see where the leak is coming from oil is coming from the back starter bolt out side top of motor then leaks on the pipe and burns the oil hopefully someone can help
Old Jul 1, 2016 | 06:30 PM
Gbodyrider937's Avatar
I have a 85 Montecarlo ss 305 just did valve cover gasket . And know it's leaking oil from some were by oil pan above it and it's leaking on my exhaust and cat
Wats the issue
89GTAOz
May 16, 2020 09:31 AM
Navy8125
Aug 21, 2015 09:32 AM
355sbcTPI
Aug 19, 2015 04:38 PM
drathaar907
Aug 6, 2015 04:20 PM
