Alternator for my new 400
Old Jul 2, 2011 | 06:55 PM
rlandrum's Avatar
Car: 1986 IROC-Z
Finally got the engine in and mounted (I had to fab the mounts - we'll see if they hold).
Brakes are done and fuel lines and electrical are this week's projects, and I'd like to install an alternator. I'm not running any accessories (no power steering, electric water pump, no ac, etc), so this alternator will be driven directly off the crank, which means mounting low, where the mechanical fuel pump would normally be mounted, I think.
Since this is strictly for drag racing, I'm not sure what I need, and was hoping someone could recommend a light weight, decent alternator and mount. Just needs enough juice to run the fuel pump, water pump, ignition, and electric windows .
I've seen on jegs several 16 volt racing batteries, and wasn't sure if a standard alternator, ignition, fuel pump, etc, would correctly charge said battery. I was actually thinking of just going with an Optima Red Top, but am open to suggestions in this area as well.
Old Jul 3, 2011 | 09:44 AM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: Alternator for my new 400
if its race only, the alt wont do much. just run good deep cycle battery. youll have to charge it when you wanna run the car, but for short runs (like down a drag strip) you dont need a whole lot of battery to run the car.
Old Jul 3, 2011 | 02:57 PM
rlandrum's Avatar
Car: 1986 IROC-Z
Any recommendation on a good brand of battery? I see Braille on jegs seems popular.
Old Jul 3, 2011 | 03:13 PM
travis401's Avatar
Car: 91 Camaro RS
optimas are deep cycle....
Old Jul 5, 2011 | 11:33 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Odyssey batteries are supposed to be pretty stout deep cycle batteries. Lots of good feedback from the stereo guys.
apie2546
Oct 16, 2016 02:24 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
SRKLEGIN
Oct 3, 2015 10:11 PM
RS Reaper
Sep 27, 2015 07:04 PM
raymondandretti
Sep 27, 2015 06:43 PM
