Can I put a engine from a automatic 2.8 into a manual 2.8..
Old Jul 24, 2011 | 09:13 PM
8928cam's Avatar
Car: 83 CaMarO Z28
Engine: 383 stroker AFR heads 600hp
Transmission: 700r4 stage 3
Axle/Gears: 373 9"
What do I have to change over on the motor?
Old Jul 25, 2011 | 12:10 AM
8928cam's Avatar
Car: 83 CaMarO Z28
Axle/Gears: 373 9"
Re: Can I put a engine from a automatic 2.8 into a manual 2.8..
Wht about going from 2.8 to a 3.1 can u use the wireing and all??
Old Jul 25, 2011 | 09:06 AM
Guest
Guest
Posts: n/a
Fir your first question, just get a flywheel for whatever year the automatic 2.8 is from. For your second question, just use the 2.8 wiring on the 3.1.
For the questions you didn't even know to ask, this isn't a swap, it's a replacement. You'll get more help in the V6 sub-forum. And if you have to replace a ruined 2.8, forget 2.8s and 3.1s, what you need is a 3.4 from a '93-'95 F-car. Direct bolt in. Still uses the 2.8 wiring, computer, et cetera, you just need the 3.4 injectors.
Old Jul 25, 2011 | 10:18 AM
8928cam's Avatar
Car: 83 CaMarO Z28
Axle/Gears: 373 9"
Well I have a 5 speed..so if I went with the 3.4 will it bolt totally up and I can use the computer and everything.from.the 2.8 or do I get the 3.4 comp??
Old Jul 25, 2011 | 11:25 AM
Guest
Guest
Posts: n/a
This doesn't get any simpler. You just need the 3.4 long block assembly, the 3.4 injectors, and a 3.1 flywheel. Everything else comes from your ruined 2.8-water pump, front cover, accessories, pullies, mounts, manifolds, wiring, distributor, everything.
The 3.4 injectors let the 2.8 computer run the 3.4 injectors.
The V6 subforum has several of us who have done this, me included, and even a couple of step-by-step guides.
The cost was about $200 for the 3.4, another $100 in gaskets, and a few Saturdays of work. Not a big deal.
The reward is 25% more torque! You can easily feel that. More torque always feels better! Highway MPG may go down 1-2, but in town MPG won't suffer.
Old Jul 25, 2011 | 11:30 AM
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
what's the reason for the 3.1 flywheel? if it's to get a neutrally balanced flywheel, the later 2.8's had them too
Old Jul 25, 2011 | 11:36 AM
Guest
Guest
Posts: n/a
But what if the OP has too early of a 2.8? The one he just lost may not be original, it may be from an '85. Ya never know.
jhawkeye
May 25, 2022 06:33 PM
Vintageracer
Jan 10, 2020 05:33 PM
camaro11j
Sep 19, 2018 08:49 AM
Zachattack0925
Aug 12, 2015 09:52 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
