ATK engines
Old Jul 25, 2011 | 02:50 PM
hartsmike's Avatar
Car: 1986 Black IROC
Engine: 305 Quadrajet
Transmission: 5 speed
Axle/Gears: 273
ATK engines
After doing much searching and hearing so much negativity about Blueprint engines I did more searching....
Came accross this: http://high-performance-engines.com/...duct_Code=HP29
Has anyone had any experience with these guys?
Thanks,
Old Jul 25, 2011 | 02:54 PM
hartsmike's Avatar
Axle/Gears: 273
Re: ATK engines
Now that I went back to their web-site I think I'm liking this one better... What do you guys think?
http://high-performance-engines.com/...duct_Code=HP32
Old Jul 27, 2011 | 06:53 AM
82tarecaro's Avatar
Re: ATK engines
I blew up an ATK engine years ago before they started building performance engines. It blew a head gasket. Even though it might have been my fault, as the car would run hot due to a bad fan clutch, they replaced it under warranty.
Old Jul 27, 2011 | 01:27 PM
Notalent's Avatar
Car: 71' Chevelle
Engine: 496ci 675HP Streetable!
Transmission: TH400 3500 Stall 9.5" Converter
Re: ATK engines
Hey Mike,
I just got a tip about this post by somone on the Chevelle forums where I often post. Please feel free to ask me any questions you may have in regards to our engines. Just searching on here, a poster by the name of SPADE has this same engine and is very happy with it. For the $ and power its hard to beat this engine and its one of our top sellers. One thing we do is use the full hyd roller cam/lifters on our engine where other companies use FLAT TAPPET...keep an eye out for that.
Brandon
Old Jul 27, 2011 | 01:29 PM
Notalent's Avatar
Car: 71' Chevelle
Re: ATK engines
Sorry to hear it blew up, but im glad we handled it wheter it was our fault or not . On the Performance end I can assure you that we do not skimp on parts for the intended engine purposes and they are fully balanced/blue printed. We do all our HP engines here in Grand Prairie, TX (Dallas).
Old Jul 29, 2011 | 10:58 PM
drop19's Avatar
Re: ATK engines
Hey Brandon,
I recently purchased a 305 TPI for my 89 IROC from you and sent in the old core for the $195. I was told you received a 305 TBI so I would not get the $195. I spoke with the mechanic who did the swap for me and he said the cores are the same, a 305 is a 305. The sales person told me over the phone today that I was probably running a 305 TBI without know it. But I had a fuel pump replaced a few years ago and remember specifically being told that the pressure on the two fuel pumps is different. I know that I am using the fuel pump for a TPI engine. Still, the salesperson said that the fuel pumps are the same. Can you please help me out?
Old Jul 30, 2011 | 11:18 AM
LS4GXP's Avatar
Car: 87 Z28
Engine: AFR 383
Axle/Gears: 4:11
Re: ATK engines
for a few hundred more go with the newer block, one piece main seal
Old Aug 1, 2011 | 08:48 AM
Notalent's Avatar
Car: 71' Chevelle
Re: ATK engines
Originally Posted by drop19
Hey Brandon,
That is a different side of the company, so I cant really help much. I can tell you this. Our core guys have a casting # database along with pictures and very good descriptions of just about every engine made. They use this for every engine that comes in. It is very common for people to have different engines than they think they do (not saying yours was or not), just from my expierience. When we get a core it HAS to be like for like to get your refund back. Alot of people try buying a 350 and send in a 305, or buy a 4 bolt and send back a 2 bolt etc etc..thinking its the same engine...sure in some sense it is, but its not. For your year car, there are 3 different 305 engines that were made....somewhere down the line, somone may have just swapped heads on the car or entire engines...
Old Aug 1, 2011 | 11:27 AM
hartsmike's Avatar
Axle/Gears: 273
Re: ATK engines
I'm liking what I'm hearing about the ATK engines so far. Think this may be route I go.
Old Aug 1, 2011 | 01:24 PM
Notalent's Avatar
Car: 71' Chevelle
Re: ATK engines
Glad to hear Mike. Like I said, let me know if I can help with anything. For the $ if you can swing it....go with the HP32. Its going to be a much nicer engine with the Hyd Roller Cam/Lifters, 1pc rear main seal and vortec heads. If you go with the Flat Tappet engines, just make sure your up to date on oils/break in proceedures...
Brandon.
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
