What Motor should I put in my iroc?
Car: 1986 Yellow Iroc-Z
I want to do a motor swap on my iroc. Right now it has a 305 tpi in it. I want to able to run 12s but not spend a boat load of money. What's my best to go with?
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Re: What Motor should I put in my iroc?
What's your budget and plans for the car?
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
350 roller with w/ 906 vortecs and a decent cam should net you about 400hp and get you close for not a lot of money.
Car: 71' Chevelle
Engine: 496ci 675HP Streetable!
Transmission: TH400 3500 Stall 9.5" Converter
Definatley need to know what kind of money your working with....Carb or EFI? You can get a stock LQ9 engine with aluminum #317 heads and cam it and it will net you 450-500HP for dirt cheap....Definatley the route I would look at. We have built a few of them and Power for $ its unbeatable.
Car: 71' Chevelle
You can buy one or you can source it used.... I have seen people score good used ones for under 2k....
Car: 71' Chevelle
If I where do a 350 with a cam and those heads then put tpi **** back on would that mess me up?
Car: 71' Chevelle
You would need the Vortec to TPI intake manifold to fit the heads with your TPI system. The other thing is for emissions...the vortec heads do not have an exhaust port passage, but the intake has provision for it....depending on the camshaft...you may need a good tune and have to upgrade your fuel system.
I would personally stick with your 350, drop a set of Edelbrock or Dart TPI heads and a nice camshaft. If you dont have $ for that than Vortecs are a good option.
I have the 305 iroc motor right now. If I can hit 400 hp I'd be happy caz it would make it faster then my dads 98 z28
If I was doing a budget build. I would get a roller 350, 906 vortec heads and the comp cam spring cut tool. Beehive spring the vortec heads and rebuild them. Get some decent rockets and proper center bolt valve covers. Add an edelbrock airgap vortec manifold a ~480 lift cam and the carb of your choice. That should get you ~350-400 hp no prob.
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Idk why swapping is the only option, boost+exhaust and a cam could probably get you there, along with a decent air filter setup, and maybe some port work. Engine swaps can be a royal time and money consuming pita, depending on complexity. Also get some decent gears if you have mpg ones, which most of the v8s do. And stock drivetrain is questionable past 300 hp btw, it should probably handle 400, but be prepared for it to not if you don't upgrade.
Ya I love turbos but I hear that does work well with tpi. And I would have to forge my inturnals right? Or how boost much can a stock 305 take?
Car: 1989 Trans Am GTA
Transmission: M28 T56
5.3L can be found much cheaper and any 5.3L into a 3rdgen will net high low 13's on street tires. Add a stall and drag radials and its instant 12s all day long.
So then what 5.3 would I want to get? You have to for give me with all the questions. I just got out of doing civics. I wanted a big boy toy lol.
Iroc8t8
May 4, 2026 08:09 PM
mustangman65_79
Aug 11, 2015 03:17 PM
