Is there a 5.0 TBI to a L98 swap guide anywhere?
Old Aug 1, 2011 | 03:02 PM
insomniac's Avatar
Car: 1991 Firebird Convertible
Engine: 5.7 L98
Axle/Gears: 3.45 9 Bolt Posi
I am getting ready to do a L98 swap into my 5.0 TBI is there a guide anywhere that can assist me in this? I want to see what I needed before I start.
I know im gonna need
ecm, harness, accessories, fuel pump
but wanted to know if the fuel lines need to be modified or any changes to the cooling system ect
Old Aug 2, 2011 | 03:09 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: Is there a 5.0 TBI to a L98 swap guide anywhere?
radiator will be the same, but the l98 would have the dual cooling fans
tbi and tpi metal lines are the same, but the rubber ones at the motor will be different i believe.
great place for wiring info on the C207 (psgr side, interior connector) and C100 (driver side firewall) connectors can be found here:
http://www.austinthirdgen.org/index.php?pid=19
Old Aug 3, 2011 | 12:45 AM
DRock89RS's Avatar
Car: 1989 RS,1991 Z28
Engine: TargetMaster 350, L98 350
Axle/Gears: 10 bolt posi 2.73s, and 3.23s
you could make it easy an just run a carb then you dont need ecms and all that.
xkingcodex
Feb 12, 2020 07:43 PM
Hello, Michael
Aug 20, 2015 03:19 PM
TheExaminer
Aug 19, 2015 10:07 PM
Randomtask2
Aug 13, 2015 01:57 AM
matthew911
Aug 12, 2015 09:38 AM
