interesting concept engine swap ideas
Old Aug 6, 2011 | 01:50 PM
marokid's Avatar
Car: 86 z28,89 iroc
Engine: 350 crate and ls1
Transmission: 700r4/4l60e
Axle/Gears: open diff stock/4th gen posi
anyone ever considerd or has done a dmax diesel swap?....ive seen it done in a chevelle in hot rod i believe...but how about in an iroc?...pros/cons.....and just food for thought any other wild ideas like a camaro with a v10 or v12....grant it u would have to do some major firewall mods or such....it would just be crazy but cool at the same time....post pix of the wildest engine swaps into a third gen you have either seen or done too!
Old Aug 6, 2011 | 02:19 PM
Guest
Guest
Posts: n/a
Re: interesting concept engine swap ideas
For the D-Max, you may well have to build a tube frame chassis around the engine. It's huge and heavy.
I've seen a you-tube of a '93-up Camaro with a Cummins from a Dodge Ram.
I believe you could fit the Dodge or Ford V-10s without bashing the firewall or moving the front core support, but the crossmember, steering, and transmission may not work out so well. Either V-10 can be T56'ed, but for an automatic, the Ford would seem easier.
If you want to be the most different, do the Renesis rotary from a Mazda RX-8, add boost, then call the car a "V-nothing" or some such.
Old Aug 6, 2011 | 02:58 PM
WickedCrazy's Avatar
Car: '91 Firebird '85 Firebird
A buddy and I looked into dropping a V10 out of a Dodge Ram into my Firebird and after realizing how much fabrication we were going to have to do (basically rebuild the whole front) we abandoned the idea.
Old Aug 6, 2011 | 03:05 PM
Guest
Guest
Posts: n/a
What if you swapped to a Viper oil pan?
Old Aug 6, 2011 | 03:33 PM
marokid's Avatar
Car: 86 z28,89 iroc
wierd you guys mention that....i odly enough just sold my v10 dodge show truck....and also had a rotary mazda turbo engine just got rid of ha
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
Fast355
Dec 2, 2016 06:33 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
