Need help wiring a 355
Old Sep 9, 2011 | 12:32 PM
meso5012's Avatar
Car: '04 Ram Hemi & '86 Camaro
Engine: 327 bored to 355
Axle/Gears: 323 posi
Dropped a carb'd 355 in my 1986 project Camaro... this car originally had a V6 in it. The wire harness that is in it now was from the V6. This is my first time doing this so can someone explain what wiring I need to complete this conversion... I would like the bare minimum as far as wiring cluddering up my engine bay. Should I go to a parts site and buy a new wire harness or can I use the old one? I've attached a few pics of the project.
Attached Thumbnails Need help wiring a 355-camaro4.jpg   Need help wiring a 355-camaro9.jpg
Old Sep 9, 2011 | 09:02 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Need help wiring a 355
All wiring from driver side firewall connector needs to stay in place - this is all your lights, horn, electrical for fuse panel, starter wires, etc. Most all wiring from pass side connector (in fender at pass floorboards) can be removed.
A few wires run from pass side to driver side ... in the wiring loom that goes over the tranny behind the motor (like fan relays wires and fuel pump relay wires, maybe a few more) - those can be fished out through the loom and bundled with the pass side wires.
MOST IMPORTANT .... don't cut anything just yet! Simply tuck the pass side wires and harness completely intact into the pass side fender out of sight. Easier to find out you need something before it's been cut out, rather than after. My ECM wires are still in my fender 5+ years later - I use them on occasion for things like fan controls, foglight wires, and anything else where I need wires from inside car to the outside - it saves me having to drill/route new wires through the firewall every time I get the urge to add or try something - I just use an existing ECM wire.
Old Sep 10, 2011 | 08:27 AM
meso5012's Avatar
Thank you for the info. It was very helpful!!!
billybob6110
Sep 24, 2016 09:50 AM
Chuck84TA
Jul 15, 2016 09:05 PM
Reddeath210
Oct 6, 2015 08:20 AM
theurge
Aug 21, 2015 12:46 PM
