LS4 Swap
Old Sep 16, 2011 | 09:17 AM
porkenstein's Avatar
Car: 91 RS Convertible
Engine: LSA
Transmission: 6060
Axle/Gears: 373
LS4 Swap
Will someone tell me if the ls4 is different than the other ls motors as far as installing in my 91 Camaro. I have read in several places it's an easier install but no one ever says why. I thought all the ls motors were basically the same as far a mounting and installing. I have a chance to pick up one fairly cheap with low miles. Thanks in advance.
Old Sep 16, 2011 | 09:19 AM
lunati397's Avatar
Car: 2012 F350 lariot/1991 Camaro RS
Engine: Powerstroke/6.0
Transmission: 6R100/4L80e
Axle/Gears: 3.73/3.42
Re: LS4 Swap
is the ls4 the FWD motor I dont think I know the LS4 or do you mean LQ4
Old Sep 16, 2011 | 09:25 AM
Engine: LSA
Transmission: 6060
Axle/Gears: 373
Re: LS4 Swap
I guess I am confused then. I thought there was an ls4 in one of the later z06 corvettes
Old Sep 16, 2011 | 09:39 AM
lunati397's Avatar
Re: LS4 Swap
LS6 then went to the LS3 and now LS7 the numbers are confusing I think the LS4 is the FWD model
If you are looking at a vette motor there are a few things that need to be swaped from a camaro LS motor before it will fit good like oil pan pickup accesories exhaust manifolds
Old Sep 16, 2011 | 09:47 AM
Engine: LSA
Transmission: 6060
Axle/Gears: 373
Re: LS4 Swap
Isn't that true with any swap. Is there one that's simpler than another. This is my first major project of this kind thought I have help from experienced people. To be honest my original idea was to go with a ramjet 350 which would be quite easy. Maybe I should stick with that idea.
Old Sep 16, 2011 | 09:50 AM
lunati397's Avatar
Re: LS4 Swap
find a lq4 or 9 they are the truck engine they have a cast iron block and good heads get a camaro pan and pickup and go from there they are very good engines and put out some big numbers
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
jharrison5
Aug 19, 2015 05:53 PM
355sbcTPI
Aug 19, 2015 04:38 PM
