What engine do I have?
Old Sep 21, 2011 | 03:51 PM
slacker27's Avatar
I have an 86 T/A which I drove in high school and after seeing this site, I have been inspired to rebuild the car. I tried searching the engine via vin number only to find it is not the stock motor in it. Can you sages tell me what kind of engine this is or what I have to do to find out which engine I have?
*Disclaimer I am new to cars so expect a lot of dumb questions*
Attached Thumbnails What engine do I have?-imag0023.jpg   What engine do I have?-imag0024.jpg   What engine do I have?-imag0026.jpg
Old Sep 21, 2011 | 04:09 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: What engine do I have?
You're sure it's not the original? If it is, it's a 305 LB9.
Old Sep 21, 2011 | 05:44 PM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
You really need to check the block castings on the side or the back of the block to know what it really is, but it looks like either an LB9 or L98. If it's the factory engine it's going to be an LB9 305CID TPI engine. They didn't come with 350's (L98) in 1986. What's the 8th digit of the VIN number? This will tell you what engine the car originally came with.
Here is the breakdown of what the 8th digit of the VIN means as far as engines go:
2 = 151ci, L4 (LQ9)
1 = 173ci, V6 (LB8)[1985]
S = 173ci, V6 (LB8)[1986]
F = 305ci, V8 (LB9)[Tuned Port Injection]
H = 305ci, V8 (LG4)[4BBL]
G = 305ci, V8 (L69)[4BBL HO}
Old Sep 22, 2011 | 03:23 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Old Sep 22, 2011 | 10:05 AM
87WS6's Avatar
Originally Posted by vetteoz
Image snip..................
Related:
That's one way to find it. Though I find it extremely difficult to actually get into a position where this casting information can be read while the engine is in the car. If you crawl under the car, the last three digits of the block casting number are stamped into the side of the block between the oil pan and the heads, spark plugs, etc. 627 for example is a very common casting number for a 305.
Unrelated:
Sweet looking engine. How much power is that thing putting down? I've got a 383 block in my garage and I'm looking to build that up and I'm wondering what power I can make with the factory TPI through porting, aftermarket runners, throttlebody etc. vs. going with a MiniRAM, etc.
Old Sep 22, 2011 | 06:16 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
I've got a 383 block in my garage and I'm looking to build that up and I'm wondering what power I can make with the factory TPI through porting, aftermarket runners, etc. vs. going with a MiniRAM, etc.
http://xtremecarzone.com.au/index.php?showtopic=386
Old Sep 22, 2011 | 09:59 PM
87WS6's Avatar
Thank you for that. I remember reading that a long time ago. This time I book marked it. No need to reinvent the wheel when I do my build.
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
