help me 305 to 350
help me 305 to 350
hi every one i have problem with the engine .. English is not my first language
so try to understand me
i have camaro 92 v8 tbi 305 so what happen is i broke the engine
so i get 350 MD engine now my problem is that the engine wont fit on the car!!
i tight the gear with the engine and when i lower the engine the
solid motor seem to be too far like 3cm from the solid motor i try to revers the engine bracket from right to lift still the same problem i try to force the engine to take it place on the body but still nothing
note : i didn't change the Solid Motor Mounts or the bracket the one fix in the block the only thing i change is the engine and it is for 89 Chevy
this is the bracket the one i mean
and this is the solid motor
