409 Swap Questions
Old Oct 1, 2011 | 03:21 AM
Kost89RS's Avatar
Car: 1989 chevy camaro rs
409 Swap Questions
hey guys
im new to the third gen site and am currently in the process of getting rid of the 305 tbi and putting in a built 409
the 409 has a holley carb and is beefed up and wanted to put it in my 89 camaro but need some help on how to do this. my biggest concern is the fuel pump in the gas tank was hoping to keep it in there and use the pump on the 409 and run it to the carb and another problem is the computer system and what to get rid of and not to get rid of cause i have the pass lock system and still want to keep tht the next problem is keeping the 700r4 with the shift kit in it and wanted to know how to make that run good with the 409 any help would be great thanx
Old Oct 1, 2011 | 03:56 PM
1gary's Avatar
Re: 400 Swap Questions
Are you talking about a "W" block 409??.
Old Oct 1, 2011 | 06:06 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: 409 Swap Questions
sbc 400, answered most of these in a another thread...
Old Oct 1, 2011 | 07:51 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
He says 409 though, not 400... which to most people means a Generation I BBC.
Old Oct 1, 2011 | 08:07 PM
travis401's Avatar
Car: 91 Camaro RS
yea, i asked that in the other thread.
Old Oct 1, 2011 | 10:15 PM
1gary's Avatar
Well ya just never know what guys have dug up to swap.There was a 409 W block yrs ago.
Old Oct 1, 2011 | 10:25 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
That is the engine everyone is referring to above
Old Oct 1, 2011 | 10:34 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Originally Posted by Kost89RS
. my biggest concern is the fuel pump in the gas tank was hoping to keep it in there and use the pump on the carb
Install a Aeromotive #13301 bypass reg ( or similar ) in the engine bay on the stock lines.
http://www.summitracing.com/parts/AEI-13301/
http://www.summitracing.com/parts/MAA-4309/
That will drop pump pressure down for carb use
i have the pass lock system and still want to keep that
Once the original setup is gone ,VATS will no longer work to cut the fuel off so no point keeping it.
All you have to do is bypass the starter enable relay
If you want anti theft protection install a hidden switch on the wiring to fuel pump
.next problem is keeping the 700r4 with the shift kit in it
Computer has no effect on how trans shifts.
All it does is control the converter lockup function so you rewire that to work with a manually operated switch.
( there are other means that will automatically operate the lockup but more $$$ )
Old Oct 2, 2011 | 06:45 AM
1gary's Avatar
Well then I have this to offer.Those engines where nearly 700lbs.The dual four barrels I think was rated at 425 hp at the f/w.Very,very,expensive to build these days.One of my friends has a 348 witch is basically the smaller version of that and paid just about $400.00 for a set of bearings.Ouch!!.
Yeah-back then with cams,you would stab a cam into it and see what it run.
Old Oct 2, 2011 | 08:38 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
The OP has a 400 SBC
https://www.thirdgen.org/forums/post...328-post9.html
Old Oct 2, 2011 | 10:46 AM
travis401's Avatar
Car: 91 Camaro RS
thats the other thread i was referring too....
Frozer!!!
Jan 19, 2024 04:55 PM
theurge
Aug 21, 2015 12:46 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
