cam change
Old Oct 23, 2011 | 10:13 PM
Whoboy580's Avatar
Car: 1986 Camaro
Engine: 383 Stroker
Transmission: Powerglide
Axle/Gears: 4.10
cam change
I am planning on waking up my car this winter. Figured I start out with a cam swap.
Here some info on my car. Its a 86 Camaro 5 speed car(TKO 600) with 4.10 Posi
Motor in the car is a SBC 350 4 bolt main 1 piece rear main seal bored .30 over. Rotating Assembly is 3.75 forged Scat Crank and 6 inch Forged H-Beam Rods with KB Forged Pistons. Its Rotating assembly is Scat Internal balanced.
Heads are Trick flow Super 23 195 Alu. Heads 72cc,Trick Flow® 1.5 Roller Rocker Arms, Trick Flow® Chromemoly Pushrods,Trick Flow Hydraulic Flat Tappet Track Max Camshafts (Duration at 050 inch Lift 246 int./254 exh.,Advertised Duration 308 int./316 exh., Lobe Separation 112, .510/.518 lift ),Trick Flow® Billet Steel Timing Sets, Edelbrock Victor Jr Intake, Holley 750Dp, Moroso 7qt storker oil pan.
Exahust is Hooker Super Comp Long Tube Headers, Custom made exhaust that dumps right before axle with flowmaster mufflers
Please help. think of hydraulic roller cam
Old Oct 23, 2011 | 11:03 PM
1gary's Avatar
Re: cam change
Before we get to that,what's the budget??.
Old Oct 23, 2011 | 11:04 PM
Whoboy580's Avatar
Car: 1986 Camaro
Engine: 383 Stroker
Axle/Gears: 4.10
Re: cam change
1,000 to 1,500
Old Oct 24, 2011 | 02:49 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: cam change
Originally Posted by Whoboy580
Please help think of hydraulic roller cam
Comp Cams XFI 280 #08-467-8 230 /236
is very popular 383 cam
http://www.jegs.com/i/Comp-Cams/249/...ductId=757952#
Crane # 119661 230 /238 (expensive)
http://www.cranecams.com/product/car...detail&p=24188
Oldy but goodie
GMPP 847 cam 234 /242
Also consider one of LE custom cams
http://elliottsportworks.com/?page_id=32
http://www.nastyz28.com/forum/showpo...78&postcount=2
NB
these are OEM style cams; the same grind is usually available in a retro fit style if you don't have a roller block .They have less duration than your present cam but way more lift
You have the rear gears to make a big cam work but might need a spring upgrade on heads for the bigger lift if you fit these cams
With a 750DP / Vic Jnr , my identical to yours 383 comb
dynoed 410RWHP with the 847 cam.
Old Oct 24, 2011 | 08:17 AM
1gary's Avatar
Re: cam change
You see the duration leaning towards the exhaust side and the 383's seem to like that.
Old Oct 24, 2011 | 02:27 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
these are OEM style cams...
I don't think that one is OEM roller. Looks retrofit.
Old Oct 24, 2011 | 05:57 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Re: cam change
I don't know how Crane differentiates between the two styles.
I have exact same part# here in OEM config
Comp at least use a different prefix # to identify OEM or retro
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Dec 27, 2019 04:14 PM
camaro71633
Sep 1, 2015 10:24 AM
nuggie
Aug 25, 2015 01:27 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
