L98 Replacement Heads
Old Oct 25, 2011 | 04:37 PM
emeryz28's Avatar
I have to replace a head gasket on my 92 Z28 5.7L and I was wondering if it would make sense to try a different set of heads to get slightly more power. I understand that in order to take full advantage of different heads it would require a different cam, but without any other modification, would a different set of heads do much for it? I'm not looking to go drag racing with it, but I would be happy gaining 20 HP which would realistically put it back to the same HP as it was when it was new.
I think the 92 Corvette has the same L98 engine, but it came with aluminum heads. Would that be a viable option and, if so, would they fit without any modification? Any suggestions?
Thanks!
Old Oct 25, 2011 | 06:19 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Aluminum heads won't buy you much, if anything. Most of the power gain from the Vette over f-body was better exhaust.
To get a power gain with heads and nothing else, you'd need some pretty good heads, like AFR or Twisted Flow. Or, Vortec heads, but those would require a different intake (base, at least).
Old Oct 25, 2011 | 07:39 PM
soarestransam's Avatar
Car: 1988 Gta trans am
Engine: LR4 4.8
Transmission: 98-02 t56 6 speed
Axle/Gears: Bw 9 bolt (3.70’s) pbr rotors
Re: L98 Replacement Heads
Its funny how everyone told me to find a set of 113 heads so I got a set for 150 bucks an now the heads aren't even that great like really jeeezzz Its all about the vortec heads these days
Old Oct 26, 2011 | 06:51 AM
emeryz28's Avatar
Thanks, guys. It looks like it will just be a visit to the machine shop to clean up my existing heads before they go back on.
Old Nov 1, 2011 | 01:26 PM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
You can use the L98 Vette aluminum heads (save about 50lbs) and maybe pickup 10hp with no other changes, probably 25 to 35 if they are ported. You can use the intake base for the Vette for either that car's heads or for any "normal" SBC heads, so your options are not limited by your present intake base. You can also use TFS, Brodix, AFR, Dart, or any other SBC heads on your motor as they will all bolt up.
Vintageracer
Jan 10, 2020 05:33 PM
CRFred
Feb 7, 2016 11:39 PM
gta90
Sep 15, 2015 04:00 PM
NBrehm
Aug 25, 2015 11:49 PM
anesthes
Aug 8, 2015 09:37 PM
