Can anyone measure their engine bay for me?
Old Oct 29, 2011 | 01:04 AM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
I don't readily have access to my car, and it has an engine in it atm anwyways(would hinder measurement taking) could someone measure for me to see if the following sized engine would fit?
height: 30(from bottom of oil pan to top of intake manifold)
width(heads) 23" (25" at exhaust manifolds)
length (transmission flange to balancer) 20.5"
Main one I am worried about is width, it is a DOHC motor.
Old Nov 13, 2011 | 09:21 PM
mackjar66's Avatar
Car: 1989 GTA
Engine: pending install 383 tpi
Re: Can anyone measure their engine bay for me?
Sounds like Ford engine specs to me
Old Nov 13, 2011 | 10:27 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
A SBC, BBC, Pontiac, Olds, Buick and Caddy engine can be stuffed into a third gen. Here are a bunch of engine dimensions. Pick yours and compare it to what you know will fit.
http://www.carnut.com/specs/engdim.html
Old Nov 14, 2011 | 01:10 AM
1gary's Avatar
Just a little unconsidered fact.The outside dimensions of a BBC for a 396 is exactly the same for a 700 ci BBC mountain motor.Humm.........
Bam.You could be the only one in the hood like it:
http://www.ebay.com/itm/NEW-BBC-FORG...-/290597928839
Old Nov 14, 2011 | 07:17 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Except a 4.75" stroke will only fit into a tall deck block and I don't think using a 5.300" stroke in a standard tall deck configuration will last for very long.
Old Nov 14, 2011 | 07:32 AM
1gary's Avatar
Yeah-that's a Big M block
Orr89RocZ
Apr 25, 2016 08:28 AM
Reddeath210
Oct 6, 2015 08:20 AM
Polo Z03
Sep 10, 2015 06:43 PM
AkDrifted
Aug 17, 2015 07:45 PM
jahblah
Aug 12, 2015 05:54 PM
