help swaping 305 tbi with TPI
Old Oct 30, 2011 | 06:03 PM
Bipolar_Bird's Avatar
Transmission: 700r4e
i have a 91 firebird 305TBI. i have got a 305 TPI out of a 88'bird came with the ECM, distributor cap no distributor, and no serpentine system.
so i need to know is
*can i use the serpentine system and distributor from my tbi engine?
*is there any problem with passing emisions with swaping engines?
*my other option is to switch block and put my tbi intake on the new block to keep things the same only the new block has been bored .030 over, will there be any problem with that or do you need to adjust anything? fuel, timeing, ecm?
just trying to make this all work and be legal, any hep would be great!!!
Old Oct 30, 2011 | 07:45 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: help swaping 305 tbi with TPI
the serpentine system and dizzy should just bolt right on the 88 engine. id stick with the 88 ecm and tpi, its better than the tbi. as far as passing emissions, unless the inspector checks out the block casting numbers, itll look exactly the same with the exception of the tpi intake.
Old Nov 7, 2011 | 07:05 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
the water pump may run backwards.the inspector gos by the vin number and will be expecting to see a throttle body.
Glowsock
Jul 24, 2025 03:15 PM
xkingcodex
Feb 12, 2020 07:43 PM
pimp2303
Jul 27, 2017 02:03 PM
92purpz28
Aug 11, 2015 02:30 PM
