cant decide on keep it or go back to tpi
Old Nov 1, 2011 | 08:03 PM
soarestransam's Avatar
Car: 1988 Gta trans am
Engine: LR4 4.8
Transmission: 98-02 t56 6 speed
Axle/Gears: Bw 9 bolt (3.70’s) pbr rotors
ok so heres my situation i got a 355 sbc (carburated) in my gta now i recently picked up a set of 113 corvette aluminum heads which are now at the machine shop getting rebuilt an cleaned up ive also ordered a thumper comp cam to go with the heads the max lift of the cam is .531 intake/.517 exhaust, rpm range is 2,500-6,200. also a set of summit roller rockers with a 1.6 ratio. i have been trying to figure out on what setup to do either a tpi which can get difficult, an really aggravated when stuff starts going wrong an breaking or keep the edelbrock intake an edelbrock 650cfm carb. in the motor i know that the whining timing gears will have to get taking out due to the knock sensor, all the tpi accessories i will have to find air intake setup, dist, etc. i have a complete tpi setup off a 5.0 (305) tpi t5 standard car sitting in my cellar going to rot an waste that i can pull out an get cleaned up an ported a little bit. the wiring harness for the tpi is still in the car also the intank fuel pump is there as well. hope to get on this situation
Old Nov 1, 2011 | 08:09 PM
ACCLR8N's Avatar
Car: 87 Evoluzione, 84 TransAm, 05 GTO
Engine: LT1, L98, LS2
Transmission: (2) T56 & (1) 700R4
Axle/Gears: Moser 12-bolt w/3.73 & Stock
Re: cant decide on keep it or go back to tpi
TPI motors are cool. Start easy, better gas mileage. Not the best match for that cam though.
Old Nov 1, 2011 | 09:20 PM
Engine: LR4 4.8
what would be a good cam/lift setup for the heads an this motor if i was to go back to tpi. that is the one thing i did like about the tpi motor i use to get atleast 250+ miles on the trip meter with the torque converter lockup on the 700r4 an tpi setup now with the carb setup im only getting about 130 miles to a full tank. my main intentions are to get a decent amount of torque,hp to the rear wheels an also get somewhat good fuel eco out of this winter build
Old Nov 2, 2011 | 02:10 PM
theNMBR27's Avatar
Car: 91 Z28 / 04 GTO
Engine: GMPP 350 TPI / LS1
Transmission: WC T5 / T56
Axle/Gears: 3.23 / 3.46
I like the TPI and plan on keeping it. I just installed a Comp Cams 268xfi hr13 cam. Depending if you port your intake or not the TPI won't "breathe" above 5200-5500 and is definitely set up for low end torque considering its an LTR set up.
Cam specs are:
1800-5800 RPM
Dur @ .050 218/224
lift .570/.565
this is all with 1.6 rockers
Old Nov 2, 2011 | 07:34 PM
Engine: LR4 4.8
yea i was told also that the tpi suffercates it's self anything above 5 grand which is kinda a bad thing with me cause i usually like to red line when i shift but i do like the high low end torque its what actually made the third gen get up an go but lack at the top end power range :-(
Old Nov 2, 2011 | 07:47 PM
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
for a street car honestly you cant go wrong with a tpi setup..it makes the best power and torque to where we street cars really use our power at anyways.. now if it was an all out race car or a car that sees alot of track time id look into a different manifold....
Old Nov 2, 2011 | 08:37 PM
Drac0nic's Avatar
What about an alternative intake like the HSR or getting something like the Accel intake? Just some food for thought. Just because you're going with EFI doesn't mean you have to use TPI.
Old Nov 2, 2011 | 10:13 PM
Engine: LR4 4.8
im trying to do this winter swap on a budget since i have the stock gm tpi setup why not use it an save some money, i was looking into aftermarket larger runners like the eldelbrock ones with a lt1 throttle body but it looked to be kinda pricey. i didnt even known accel made a tpi setup i thought accel was just a aftermarket ignition company that sold ignition wires, spark plugs, an injectors i had no idea they did intakes a other stuff
Old Nov 2, 2011 | 10:17 PM
Aaron_SK's Avatar
Car: 1985 Sport Coupe
Engine: 3800 Series II Turbo
Transmission: 4th-gen WC T5
Axle/Gears: 3.27 BW Limited
TPI Will kill half the range of that cam. You'll be done and shifting by 4600 rpm.
Run a low end cam or a high-end intake, otherwise you're just flushing money.
Old Nov 2, 2011 | 10:47 PM
Engine: LR4 4.8
so you are talking about a cam from idle to about 5000 thats pretty much the low end of a sbc anyway if im correct
Old Nov 3, 2011 | 01:07 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Take another look at the Holley/Weiand Stealth Ram. It is base/runners/plenum in one package, and costs about the same as aftermarket TPI runners alone. Its powerband will support your current cam.
http://www.summitracing.com/parts/WND-7540/
Old Nov 3, 2011 | 08:24 PM
Engine: LR4 4.8
I must say holy cow that stealth ram set up is perfect I didn't even know that holly did those intakes but what I'm wondering is will this setup work with the timing gears whine that I have or will I have to change that also do they make that intake bolt up to corvette 113 L98 heads cause if so I'm definitely gonna order that intake in the near future
Old Nov 6, 2011 | 08:12 AM
TransAmSteve's Avatar
Car: 91' Trans Am 1le
I've got a question on that stealth ram does anyone know if factory tpi fuel rails will work on that? Because this has sparked my interest in that intake as well
Old Nov 6, 2011 | 05:51 PM
Engine: LR4 4.8
No it doesnt I looked up u would need to buy the Holley fuel rail kit it's a extra 200 bucks it comes with the o rings, adjustable regulator, all the fittings To hook up to the stock fuel line setup
Old Nov 6, 2011 | 06:03 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
get this !!! http://forums.corvetteforum.com/c4-p...ram-setup.html
Old Nov 6, 2011 | 07:49 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
too late, its already sold . but yea tpi barely lets a 305 breath at higher rpms. let alone a 350. if you want a power band to about say 5grand, you arent gonna get it without heavily modifying the stock tpi. i wouldnt mind taking that tpi off your hands though
Old Nov 6, 2011 | 09:42 PM
Engine: LR4 4.8
well if u wanted to buy the tpi setup i would want at least 200 bucks for the whole setup ill even throw in everything dizzy plenum runners intake throttle body. Also for an extra 75 bucks i also got a 88 tpi wiring harness with no ecu or prom
Old Nov 6, 2011 | 10:33 PM
Yeah I was looking it up earlier and didn't see anything about the fuel rails. I did notice however that they recommended a twin 58mm throttle body which I currently have on my car and have been told its too big for a mildly built 350. So I'm curious as to which would be best with that intake on a mild 350.
Old Nov 7, 2011 | 12:27 PM
travis401's Avatar
Car: 91 Camaro RS
stock lt1 or holley twin 58. the stock lt1 would probably be better for the mild build and probably cheaper to boot.
Ghettobird52
Jul 5, 2024 11:18 PM
BurlyChev
Aug 16, 2015 09:08 PM
Sanjay
Aug 12, 2015 03:41 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
topteam54
LSX and LTX Parts
Aug 11, 2015 07:15 PM
