k member?
Old Nov 8, 2011 | 05:39 PM
tylercamaro's Avatar
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Transmission: TH350, 4L80E
Axle/Gears: 3.42, 3.73
k member?
v6 and v8 k members are the same except for where the engine mounts are on it correct? i havent tore my other cars engine to determine but i just figured id use my other one but need pics of the v8 mounting locations please
Old Nov 8, 2011 | 06:24 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: k member?
yes, k members are the same. itll have both holes drilled for both v6 and v8 motor mounts. v8 mounts are the front holes.
Old Nov 8, 2011 | 06:27 PM
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Re: k member?
hmmmm, thats odd then. the supposed v6 kmember had the mounts in front already. got any pictures that may help? im swapping in a 5.3 so im assuming the adapters will just go in place of the v8 mounts
Old Nov 8, 2011 | 06:48 PM
travis401's Avatar
Car: 91 Camaro RS
Re: k member?
the v6 is a smaller engine, and therefor needs to sit further back on the kemember for the trans to bolt to it without having to have a seperate trans xmember than the v8s. if the v6 mounted in the same spot, then the trans would need to be moved further forward and it would need a longer drive shaft.
and yes, the 5.3s adapters will bolt in place of the stock v8mounts (as far as i can gather, im no LS expert)
if you have a kmember to look at youll see the front holes are actually spaced out further than the rear holes. the v6 mounts are smaller so the bolt holes are spaced closer together.
not my car, but this is the v8 mounts
Old Nov 8, 2011 | 06:52 PM
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Re: k member?
allrighty good stuff thanks travis. also do you know how to get that stupid sterring box off. i removed every bolt possible and it wont budge
Old Nov 8, 2011 | 07:04 PM
travis401's Avatar
Car: 91 Camaro RS
Re: k member?
its held on with 3 bolts through the frame rail. might need a nice whack with a hammer
Old Nov 8, 2011 | 07:13 PM
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Re: k member?
alrighty good stuff.
Old Nov 9, 2011 | 05:09 PM
Pocket's Avatar
Car: 91 Trans Am
Re: k member?
Probably missed a bolt, that devil is heavy
Old Nov 9, 2011 | 05:16 PM
travis401's Avatar
Car: 91 Camaro RS
Re: k member?
its just the 3 bolts through the frame rail and the bolt holding the shaft on right?
Old Nov 9, 2011 | 07:22 PM
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Re: k member?
i thought there were two on the frame from the wheel well and one below on that brace that ties in with the k member
Old Nov 9, 2011 | 07:25 PM
travis401's Avatar
Car: 91 Camaro RS
Re: k member?
its been a while since i pulled mine off. i cant remember exactly.
Old Nov 9, 2011 | 08:47 PM
Pocket's Avatar
Car: 91 Trans Am
Re: k member?
3 bolts sandwiching the frame. One is behind the battery tray brace
Useless trivia, its the only 5/8" bolt on the car
Old Nov 9, 2011 | 08:52 PM
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Re: k member?
so 4 bolts hmmmm, wheres the 3rd. theres two visible from the wheel well one under and the 3rd frame sandwhiching one is yet to be found. im about to go look and zip it off real quick
Old Nov 10, 2011 | 06:58 PM
85z28kid's Avatar
Car: 85 iroc-z28
Engine: 049 headed bbc 4?? C.I.D
Axle/Gears: 3:73 posi
Re: k member?
You have to move the battery box brace if you look close at it it's notched around it for the head of the bolt. Just look where the brace attachs at the frame and you'll see it.
Old Nov 10, 2011 | 07:04 PM
Twin_Turbo's Avatar
Re: k member?
Old Nov 10, 2011 | 07:43 PM
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Re: k member?
twin turbo is the man. no homo i love that guy. hes always got the pics that help out tons and they all look so pretty. and to everyone else that helped, i love you all also. no homo. i wouldve never ever ever seen it there when all the surface rust/ nasty old undercoating sorta blends stuff together
Old Nov 11, 2011 | 08:16 PM
travis401's Avatar
Car: 91 Camaro RS
Re: k member?
stock maybe, Ive got 4 5/8" bolts holding my spohn trans xmember in.
Old Nov 11, 2011 | 08:40 PM
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Re: k member?
hey pocket howd you know they are the only 5/8 bolts. i just thought about it and i wish there was a list of what bolt was what size. thatd make life tons easier
Old Nov 11, 2011 | 09:10 PM
Pocket's Avatar
Car: 91 Trans Am
Re: k member?
Theres not a bolt I havent turned on a 3rd gen a dozen times over
Old Nov 11, 2011 | 10:32 PM
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Re: k member?
you should make a list and post it on the boards so guys can print it off and use it
Pac J
May 17, 2020 10:44 AM
92rsvortec350
19
Oct 9, 2015 09:39 AM
LT1Formula
Oct 8, 2015 08:34 PM
