Duramax Thirdgen Swap
Old Apr 20, 2012 | 09:57 AM
  #251
lunati397's Avatar
Car: 2012 F350 lariot/1991 Camaro RS
Engine: Powerstroke/6.0
Transmission: 6R100/4L80e
Axle/Gears: 3.73/3.42
Re: Duramax Thirdgen Swap
dry sump is money I can modify the pan for my time I can put the duramax in from the top the trans has to go in from the bottom and conncted to the engine
Im going to find another stock turbo and run duel stockers and fabricate new exhaust manifolds
Old Apr 20, 2012 | 10:10 AM
  #252
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
What sort of hood do you have to run to now accommodate twin relocated turbos? Any ideas? Maybe build the setup, cut up a flat hood around it and figure it out that way?
I'm asking because I'm thinking of doing just that with my single turbo project. Maybe do a rough cut out with a flat hood, then I can see what needs to go where.
Great project man, I really enjoy watching it.
Old Apr 20, 2012 | 10:18 AM
  #253
lunati397's Avatar
there will be no cutting at all I have a SS hood now and it has a 2 inch cowl but now that im going with twins it will be alot lower the turbos will be up front one behind each headlight setup and that way I can free up more space behind the motor too and set it back as far as possible
Old Apr 20, 2012 | 10:57 PM
  #254
lunati397's Avatar
Old Apr 30, 2012 | 01:21 PM
  #255
vicg1's Avatar
wow
Old Apr 30, 2012 | 04:25 PM
  #256
budget builder's Avatar
Car: 91RS
Engine: carb'd 357 vortec
Axle/Gears: 3.42 posi
incredible!!!!!!!!!!!!!!!!!!!!!
Old May 1, 2012 | 10:32 AM
  #257
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
subscribing
Old May 1, 2012 | 11:57 AM
  #258
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
How the heck did I miss this thread, subscribed...
Old May 1, 2012 | 01:16 PM
  #259
lunati397's Avatar
sneaky sneaky so ive pulled the manifolds and and im about to stuff it back in there hook up the trans get it straight and fab up the motor mounts im going to take the manifolds to a buddy and have him water jet some plates for me to build manifolds off of for relocating the turbo(S)
Old May 1, 2012 | 06:56 PM
  #260
Brando5641's Avatar
Car: 1998 Trans/Am, 1989 RS Camaro
Engine: LS1, LQ9 6.0
Transmission: 4L60E, 4L60E
Axle/Gears: 2.73, 2.73
GOD that thing looks heavy
SUBBED
Old May 2, 2012 | 08:15 AM
  #261
lunati397's Avatar
830 fully dressed I think I can get it down to 740 with new manifolds relocating or replacing the turbos
Old May 2, 2012 | 09:52 AM
  #262
ricklee4570's Avatar
Awesome! I cant wait to see how it all works for you when it is complete!
Old May 2, 2012 | 04:36 PM
  #263
86_irocz-28's Avatar
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
rear mount single/twin turbo's?
Old May 2, 2012 | 04:59 PM
  #264
lunati397's Avatar
right now im looking to doing twins up front one behind each headlight setup
Old May 3, 2012 | 09:38 AM
  #265
lunati397's Avatar
with the turbos up front that makes the highest point the intake and well I cant have that so it to will be coming off and I am thinking of fabing up a whole new intake maybe simular to the banks big hos intake and I might have to get a spoolmate for my welder and a new tank of gas
Old May 10, 2012 | 11:08 AM
  #266
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Holy crap Nice job man subscribed.
Old May 18, 2012 | 11:58 AM
  #267
lunati397's Avatar
Ive been working weekends and on other peoples cars alot lately so there is no progress but im finishing up one car and another so I HOPE ill have some free time along with a 4 day weekend coming up
also buying a new truck right now so my old one is for sale if anyone is looking for a 2008 heavy duty half ton LTZ
Old May 31, 2012 | 02:16 AM
  #268
navarrat's Avatar
Car: 1990 Camaro RS
Engine: 305 L03
Transmission: 700R-4
Axle/Gears: 2.73 Posi
SUBSCRIBED!!!!!!
Old May 31, 2012 | 03:51 AM
  #269
the209bnr's Avatar
Car: 1984 Pontiac Trans Am
Engine: L69
Transmission: THM-700R4
Axle/Gears: 3.73 Posi
Subscribed as well
Old May 31, 2012 | 04:15 AM
  #270
pvr007's Avatar
Car: 88 RS Camaro,70 chevelle,92 Geo
Engine: 305 TBI
Transmission: 5 Speed Manual
suubeed
Old May 31, 2012 | 10:57 PM
  #271
j88l98irocz's Avatar
Car: 88 IROC-Z twin turbo
Engine: forged 383 8-1 compression
Transmission: t56
Axle/Gears: 9in 3.50's trac loc moser axles
Subscribed
Old Jun 1, 2012 | 08:43 AM
  #272
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Looking like this one won't get finished. No updates, not even any excuses. Curious how many subscribers here can and will copy this if it ever gets completed? I'm solidly in the camp of just curious about the idea. I've driven an '06 Dmax 2500HD, I understand the appeal of this swap, but it's looking like a fabricator's headache. Plus the weight and cost are both as excessive as the fab work required. Come on Lunati397, or I'll be the first with a diesel running, even if my non-turbo 6.2 isn't as fun to drive.
Old Jun 1, 2012 | 01:14 PM
  #273
lunati397's Avatar
Im working it and gave a status update I am in the Airforce and either between Temp duty and 12 hour shifts I havent had the time even this weekend just got ruined becuase I found out today that I will have to come in and work. That on top of doing a V6 to ls6 auto to 6 speed swap on a firebird and a 6.0 swap into a 85 caprice and a 6.0 swap into a older impala and now I have a ditchwitch with a broken timing gear for a ancient motor so I have to get it machined and I am the only powdercoater in town so I do keep pretty busy
Fabrication isnt and issue right now I have the motor in and I am about to make the mounts to get it in for good I am also not just putting a motor in to get it in I am smoothing cleaning and doing all the finishwork to it looks good too.
If i wanted to put a 400 in I would have gone with a 6.2 not to put your swap down because I like what you are doing and at your rate you will be first but there are two ways to do things the right way and again and I am a perfectionist so I want it all to be top nocth once around
Old Jun 1, 2012 | 01:16 PM
  #274
lunati397's Avatar
theres an update and it will be finished
BTW sold my truck and got a 2012 F350 Lariot went to the dark side but had good reason 14.5 out of my half ton and im getting 19.5 out of my new 1 ton and the new powerstroke is a good looking motor design wise and its silent (bears a striking resemblance to the GM 4.5 that got canned a few years ago)
Old Jun 1, 2012 | 02:45 PM
  #275
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Sorry if you felt attacked, I was actually in the mood for good-natured, casual conversation. Same right now: Sorry you're swamped, with no breathing room. Maybe I should be glad the Navy never let me in, all those years ago? Yeah, I want mine to look clean and neat, but I don't see any sense in worrying how anything looks until every part is finalized for fit and function. That's how the most-in-demand pros do it, so that's how I do it. I tried to get Fallen2603 to understand this with his Ecotec IROC-Z, but you guys seem to prefer driveway paperweights over showable drivers. Right now it looks like I won't be making it to the 2012 Cruise-In, so I should have my engine washed, partly dis-assembled, re-painted, new gaskets, reassembled and running in time for next year. Then pull the engine the day after the 2103 Cruise-In, since by then I'll have MPG numbers and proof. Plus by then I'll have my next drivetrain combo ready to final-install and drive. Finalize the designs, go for a test drive, then we'll all be convinced. After that you can take it back apart, make everything look however you want, and stay more motivated all the way through the entire process. Or if it can't be what you hope / expect, you'll find out before you put too much extra money and effort into the project.
Old Jun 1, 2012 | 03:30 PM
  #276
lunati397's Avatar
I am just taking my time im not giveing myself a deadline or anything because anything can come up but one thing will stay true when I get started I will finish and when it comes down to it where I make a few grand doing someone elses car or mine I go for making the money it makes it so I can afford to buy good tools and equipment
If it came down to it I can have it in and running in a week or so but it will look like crap and be half assed and I have done that before and it always comes back around to bite you in the *** because once its running and good you dont want to pull everything out again
Old Jun 1, 2012 | 05:05 PM
  #277
DIGGLER's Avatar
have you got the wiring figured out?
i just bought another '07 lbz engine a couple of weeks ago. 135k miles on it. it was getting coolant out the exhaust somehow. they put a new set of head gaskets on it, but the problem continued. im in the process of trying to diagnose the original problem.
gotta rig it up so i can pressurize the coolant system on the engine and check for leaks. if i pull the heads it will cost me $800 to put them back on there, so im trying to avoid that.
so far i have owned:
1 '06 lbz with a broken crankshaft
1 '06 lbz with a bad wrist pin bushing and damaged cylinder wall
1 lb7 with good shortblock but some sort of topend issue
1 '07 lbz with possible cracked head
im glad some people have good luck with these things. lol
Old Jun 4, 2012 | 07:41 PM
  #278
lunati397's Avatar
I havent tried on the wiring I was going to send it out but I just built two LS harnesses so ill just end up doing this one
The 85 Caprice I did the LS swap is done and gone now but I did just pick up another job with a 88 impala doing a LS swap but Hopefully im not working this weekend and I can get the motor mounted and start working on the exhaust and turbo mounting
Old Jun 5, 2012 | 08:57 AM
  #279
BlwnSS's Avatar
Car: 1999 Formula Hardtop
Engine: 6.2 forged ls3 Procharged
Transmission: t56 Magnum
Axle/Gears: midwest chassis fab 9/3.50
get this duramax in there , always been a dream of mine to do in my 85 . I always think of the mustang on the power tour that was running 10s and getting 38mpgs .
Old Jun 5, 2012 | 09:38 AM
  #280
Lt1Chris's Avatar
Car: 01 Acura TL
Engine: 3.2 Vtec
Transmission: 5 speed
Axle/Gears: ?
sub
Old Jul 20, 2012 | 09:32 AM
  #281
lunati397's Avatar
I have been real busy did 4 LS swaps and rebuilt a motor on a 1950s ditch witch at least everything was standard lol I have gotten my garage cleaned up work is slowing back down so no more working weekends and 12 hour shifts I have one more LS swap finish up a firebird as soon as the guy gets the cash to get the clutch parts and I am free and clear of other peoples projects
We will have some progress in Aug and this winter I am hopeing to wrap it up
Old Jul 20, 2012 | 10:19 AM
  #282
tylercamaro's Avatar
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Transmission: TH350, 4L80E
Axle/Gears: 3.42, 3.73
sometimes working and getting the extra cash can postpone your project but make it move along faster later on. keep up the good work if you have pics of the customers cars and they let you, i and probably everyone else would love to see them
Old Jul 20, 2012 | 10:30 AM
  #283
lunati397's Avatar
well here is where some money went
OLD
New
Old Jul 20, 2012 | 11:03 PM
  #284
NullHead's Avatar
Car: 1991 Pontiac Firebird
Engine: 305 TBI
Axle/Gears: 3.73, Detroit Trutrac, 10 bolt
Nothing wrong with the snapon lower box ... but a bit small. What brand is that new one? Looks pretty nice! Plenty of room in that box you'll soon fill it up, but the storage is more efficient.
Old Jul 21, 2012 | 07:44 PM
  #285
lunati397's Avatar
it was just to small the new one is kobalt not as nice but I am suprise with the quality being better than what I expected and tons of space and a radio a nice thing to have
Old Aug 22, 2012 | 08:47 PM
  #286
lolvtec's Avatar
Car: 1991 camaro RS convertible
Engine: EFI 383 150shot nitrous.
Axle/Gears: 2:73...
i got the same tool box its even got a spot to keep your beer cold lol
Old Aug 23, 2012 | 06:59 AM
  #287
jhainer's Avatar
Car: 1986 BBC Iroc
Engine: 454
Transmission: th400
I have the same one two but mines without the radio
Old Sep 15, 2012 | 08:13 PM
  #288
3rdGenFreak1227's Avatar
Car: 86 IROC Z
Engine: LQ4
Axle/Gears: 4th gen 10 bolt 4:10
Coolant is coming from the EGR cooler...they get plugged up and sometimes leak...done a TON of them at the dealership
Old Sep 15, 2012 | 10:57 PM
  #289
DIGGLER's Avatar
really? i was hoping for that, but when i pressurized it (best i could anyways) i didnt notice any leaks. thanks for the headsup, ill check again.
Old Sep 15, 2012 | 11:10 PM
  #290
lunati397's Avatar
ive got a guy that does my harnesses for LSX swaps that is doing the duramax harness for 250
Old Sep 16, 2012 | 12:07 AM
  #291
FryeDaddy's Avatar
Car: 85z28(sold),91 rs, 15'Mazda3GT
Engine: 5.7L V8 350 (ZZ4)
Transmission: 700r4 rebuilt with kits+ vette serv
OLD
New
Good choice with the sound system... haha got one of those too and it's pretty nice
Old Sep 16, 2012 | 07:10 PM
  #292
lunati397's Avatar
Ive been very busy this summer im on LS swap number 10 now rebuilt a ditch witch got a new truck and the regular day job and up until july I was working every weekend and 12 hour shifts
but got some new goodies
Upgraded my air compressor from a 60 gallon to a 80 gallon 2 stage got another good tool box a car trailer and a 1936 dodge truck a few days ago that i will be turning into a rat rod
so far just redid the wheels so i can move it around
the duramax will be my goal this winter I have someone that will do the harness and the k member is in and a arms are good just need coil overs to get it rolling again
Old Sep 16, 2012 | 07:24 PM
  #293
BOTTLEDZ28's Avatar
Transmission: A4
This swap has gone through my mind for about a year now but I just cant see going backwards in my build so I now will watch you build yours and hope it works out perfect for you. Good job so far.
Old Sep 16, 2012 | 07:28 PM
  #294
lunati397's Avatar
ive got 3 customer cars to finish up and then im not taking anything else on I will have it running by spring
Old Sep 16, 2012 | 08:45 PM
  #295
NullHead's Avatar
Engine: 305 TBI
So ... just curious. What'd you do with your old compressor?
Old Sep 16, 2012 | 09:02 PM
  #296
lunati397's Avatar
traded it and a oxy acetylene setup for the 1936 dodge
Old Sep 16, 2012 | 09:14 PM
  #297
NullHead's Avatar
Engine: 305 TBI
Ahh alright ... Probably was the better deal for you anyways :P
Truck looks sweet though. You need to post pictures of that build for us too.
Old Sep 16, 2012 | 09:16 PM
  #298
lunati397's Avatar
beds getting shortend to about the length of the back fender so its loosing about 4 ft and ive got a 350/350 going in it
Old Sep 16, 2012 | 09:35 PM
  #299
72vega's Avatar
Car: 2008 Silverado, 73 LeMans, 1987 GTA
Engine: 4.8, 350 Pontiac, 350 LT1
Transmission: 4L65E, TH350, T56
Axle/Gears: 3.42, 2.73, 3.42
thats a friggin hell of a trade!
Old Sep 16, 2012 | 09:38 PM
  #300
lunati397's Avatar
I put the barter king guys to shame I traded a 350 for the matco tool box and I traded a set of 20s that I got for powdercoating some bike parts for the aircompressor
