help finding cam retrofit parts
Old Nov 19, 2011 | 03:49 PM
ChevyRS-305's Avatar
So i have been doing my research about retrofitting a hydraulic cam. I also searched the forums and found nothing useful so figured with your help we can make a parts list of EVERYTHING that is needed for the cam swap.
#1 for starters i know you need a retrofit hydraulic roller cam
#2 retrofit Hydraulic roller lifters(t- bar style)
#3 new pushrods
#4 bigger valvesprings
#5 roller rockers
#6 a rigid timming chain cover (something like a 2 piece billet aluminun)
#7 camshaft button( optional camshaft bolt retainer)
#8 new timing chain and gears
#9 thrust bearing (sits between the camshaft and and cam gear)
#10 (optional depending on our setup) soft metal distributor drive gear if your using a stock distributor, or get a retrofit hardened distributor drive gear.
If i missed anything or any comments please put what reference part #. If any specific parts please put down the full part number and where to find it.
Old Nov 19, 2011 | 04:01 PM
Re: help finding cam retrofit parts
#11 also heard about a thrust plate. Is this an aftermarket part or something that cam on a factory post-87 block? Or is it pre -87? Also heard something about cutting off the ears... this has quite stumped me
Attached Thumbnails help finding cam retrofit parts-148_0307_roller_12a_z.jpg
Old Nov 20, 2011 | 06:45 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
thrust plate.
Can also use a factory style roller cam ( cheaper ) with the cut down roller cam retainer plate as a spacer to fill the lip on the front of the stock roller cam.
Must use factory style roller cam timing set with this method
i know you need
#5 roller rockers
Valve springs need to suit lift of cam
Roller rockers optional ( not required as part of swap )
Flat tappet timing set fits retro fit style roller cam.
OEM style roller cam must use OEM style roller cam timing set
Old Nov 20, 2011 | 11:12 AM
So if you use a retrofit cam you do not neet to use a thrust plate and cut off the ears?
Reborn756
Sep 4, 2015 03:42 AM
1988iroc350tpi
Aug 14, 2015 07:52 PM
Fronzizzle
Aug 9, 2015 01:15 PM
1nastygta
Aug 8, 2015 07:38 PM
guy76767
Aug 6, 2015 05:58 PM
