454 on fleebay. worth it?
Old Nov 23, 2011 | 05:45 PM
scorp88's Avatar
Car: '92 Angrybird
Engine: 305 TBI the "Leaky Bastard"
Transmission: 700R4 with B&M shifter
Axle/Gears: 3.21 Posi off of '93 Camaro(RIP)
I was browsing through ebay and found this:
http://www.ebay.com/itm/2005-454-GM-...sories&vxp=mtr
Does it look like a good deal?
Old Nov 23, 2011 | 06:19 PM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
Re: 454 on fleebay. worth it?
Honestly it does not, the lifter valley is dark at least by the picture...a 6,000 mile engine would be bright and clean even if the oil was never changed, looks like 60thou at least imo...then the add doesn't even state that its useable and not a damaged engine... just says "454 6,000 miles" better talk with the seller before bidding is all I can say
Old Nov 23, 2011 | 06:36 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
its listed for local pick up only. if its local email the seller and ask to come look at it before bidding
Old Nov 23, 2011 | 08:27 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
That lifter valley doesn't look too bad on my monitor but personally, $1500 is too much for that engine just from what I can see. It's not a performance engine, the intake system is missing plus who knows what else. I can see paint pen marking on the heads so it's been pulled and marked for sale by a wrecking yard.
6000 miles or not, without hearing it run or stripping it down for inspection, it's worth maybe $800 as a core.
If it was a complete running engine then $1500 would be a good price for a stock replacement engine.
Old Nov 23, 2011 | 08:30 PM
LsxMatt's Avatar
Car: 86 Sport Coupe
Engine: 5.3 LM7
Axle/Gears: 4th gen 3.42 posi
The seller has 0 feedback too so who knows...
Old Nov 23, 2011 | 09:07 PM
scorp88's Avatar
Car: '92 Angrybird
Thanks for replies everybody!!! Your input is much appreciated. I am 5 hours away and going there to look at non-runnig engine is deffinetly a no-go. I have no idea how 6000 miles BBC should look like as I've never seen one apart I guess I'll pass then. Cheers
Old Nov 24, 2011 | 11:17 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Make an $800 offer and see what happens.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
skinny z
Oct 5, 2015 06:23 PM
bjpotter
Oct 4, 2015 07:48 PM
gord327
Oct 3, 2015 01:25 PM
