will this stand be alright
Old Nov 24, 2011 | 06:53 PM
justcallmeclassy's Avatar
Car: 1992 Camaro RS Z03 T-Top
Engine: L98 with TBI
Axle/Gears: 2.73...
Noob question, does anybody know if this stand going to be good enough for a sbc? Im gonna tear down a 350 and the budget is tight and this thing is cheap. The seller doesn't know the brand or specs but says it'll hold it, but like I said ima noob lol.
Old Nov 24, 2011 | 06:55 PM
Pillsbry10's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
Re: will this stand be alright
yes just be very careful rolling it around
Old Nov 24, 2011 | 06:58 PM
Axle/Gears: 2.73...
Ahh I see your point, is it bc only 3took wheels wouldn't be stable? Plan on putting the thing in the corner and leaving it there
Old Nov 24, 2011 | 07:00 PM
Pillsbry10's Avatar
correct...if the front wheel gets hung up itll tip real easy.
Old Nov 24, 2011 | 07:03 PM
Axle/Gears: 2.73...
Gotcha thanks for the advice there, im pretty paranoid so it would braced up
Old Nov 25, 2011 | 08:00 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I built my first motor on a 3 wheeler like that, and then it held a 305 for years. With the fully dressed motor, the motor seemed to tilt down quite a bit, but it never went anywhere.
Now I only use that stand to hold the motors coming out of the cars. For the $50-60 that a better stand costs, I don't want to risk tipping over a 3 wheeler and trashing a good motor.
Old Nov 25, 2011 | 11:26 AM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
yea, i used to have a 3 wheeler. they want to tip easy....best way to move it around is to pull it from the back, never push it. shold be fine to hold a motor in the corner of the garage for long periods of time.
Old Nov 25, 2011 | 12:23 PM
ex-x-fire's Avatar
Do you have any buddys that got a welder? I betcha you could add 2 casters to the front.
Old Nov 25, 2011 | 12:27 PM
Impaqt's Avatar
Car: 88 Iroc-Z Convertible
I had a stand like that a long time ago. I welded a cross bar across the front foot just to make sure in the event it started tipping, it wouldnt go far.
skinny z
Carburetors
Sep 29, 2015 11:25 PM
88rscamar0
Sep 23, 2015 09:08 PM
anesthes
Sep 18, 2015 12:34 PM
Kingchevy
Carburetors
Sep 17, 2015 12:09 PM
ericjon262
Sep 11, 2015 06:07 PM
