3rd gen lt1 swap HELP!
Old Dec 5, 2011 | 07:50 PM
SS350scott's Avatar
Car: 1988 camaro
Engine: 350 ci LT1
Axle/Gears: Ford 9in w/ Strange 3.70s
hey everybody, im currently putting a 1996 impala ss lt1 into my 1988 camaro. anyway i was just wondering what are the best set of aluminum heads and currently more importantly, what is the best choice for a set of longtubes, offroad x pipe that will fit a third gen with this swap
Old Dec 5, 2011 | 07:58 PM
SS350scott's Avatar
Car: 1988 camaro
Engine: 350 ci LT1
Re: 3rd gen lt1 swap HELP!
p.s. after about a year i will be completely rebuilding the motor in order to handle 20+ lbs boost
Old Dec 5, 2011 | 08:20 PM
lunati397's Avatar
Car: 2012 F350 lariot/1991 Camaro RS
Engine: Powerstroke/6.0
Transmission: 6R100/4L80e
Axle/Gears: 3.73/3.42
golen engine for the shortblock and advanced inductions lt4 heads made 550 rwhp NA with a 9.8to1 ratio with my last setup I had the lower ratio because I was planing of future boost
Old Dec 5, 2011 | 08:35 PM
SS350scott's Avatar
Car: 1988 camaro
Engine: 350 ci LT1
so i would be better off swapping lt4 heads rather than say edelbrock performers? and since you've said the short block was great for boost, would you recommend a forged rebuild or stock internals?
Old Dec 5, 2011 | 08:36 PM
SS350scott's Avatar
Car: 1988 camaro
Engine: 350 ci LT1
also where did you get the cold air intake on your previous set up?
thanks
Old Dec 5, 2011 | 08:52 PM
lunati397's Avatar
mine was just a holley cold air intake I would go forged if you plan to boost but remember 20 psi is hard to get on a v8 not like a 4 banger you have to move alot of air to make 20 that means HUGE turbo to be efficient they dont make LT4 parts anymore but go with the edelbrock of trickflow LT4 heads and intake and I liked the LT4 hotcam or the GM847 was alot of fun
I spent around 9000 to build my setup I went all new with everything so expect to pay to play you can do a LS1 and get more power for less or LQ4 LQ9 L92<---the best
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
sreZ28
Aug 14, 2015 07:48 PM
reiderz iroc
Aug 13, 2015 04:57 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
