Ls7 swap or bore the 305 tpi 30 over
Old Jan 6, 2012 | 02:57 PM
  #51
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
Re: Ls7 swap or bore the 305 tpi 30 over
Originally Posted by thesargster4
Next time you get the chance to go diving and catch a glimpse of a ship that is anchored, look at the end of the chain. You should see a 305.
LS7 for $500? BULL.
LMAO... I found this to be most hilarious. I was all into it thinking "What does diving have to do with LS7's and 305's?".. Nice one.
An LS7 block is probably worth more than an IROC in "ok" shape.. But even a block for 500$ is a good deal if he can get it .. I'm guessing no rotating assembly or anything? That's a big huge job and it might be better to find a wrecked Z06 parting out with the whole engine from intake to oil pan + ECM and other little parts that you could use.. Or better yet, a wrecked SS Camaro and get all the LS3 + T56 stuff from that.. When I have the $$$ that's what I will be doing.
The LS7 is strong, reliable, powerful, etc. but not worth the money when you consider $ per HP that it costs.
But this probably is just a hypothetical engine swap thread.
BlueIroc-Z
Jun 9, 2019 03:22 AM
drewdock87
South Central
Aug 18, 2015 09:02 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
