Wires needed to run 350
Merry Christmas!!
I have searched, but dont have a clue.
I had a computer carb'd 84 with 305 and swapped in a newer 350, but want to go to a non-computer carb.
First of all, I have seen the Carb Swap posting on this site....
Can someone send me a link to a posting or maybe explain the wires I need to hook my non-computer carb'd 350? I figure the alt, battery, starter, and distributor (I already have a non-comp vacuum advance dizzy).
I also need to replace the throttle cable. (It has a length of STRING sliced into it... Really) I can just order a replacement for the original 84 carb, right?
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: Wires needed to run 350
The engine will run as long as it's grounded and you've got the power wire going to the distributor. Then it's a matter of turning the starter.
The gauges are the complication... al ot of those wires go to gauges and fuel system and headlights and so on and so forth.
Car: 84 sport coupe
Axle/Gears: stock
i converted my sport coupe from a 2bbl computerized v6 to a 350 non computerized basically all you have to is put the motor and tranny in and buy and hei distributor the only wires you need in your old harness are the ignition power on the coil, the tach wire on the coil, your oil pressure, sensor wire and coolant temp sensor wire and your good. just dont use a computer controlled tranny i basically just cut out all the bs thats in the bay its just in the way and makes it look bad
Thanks for the responses. I still have the 700R tranny. I will worry about that later. I just want to see/hear the beast belch fire and smoke.
Thanks again. Happy New year...
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
All you need for that is a way to control the lockup. You can do a switch or I think it's B&M that has a kit for it.
Or you can do it manually with a simple switch.
