305 LB9 300 HP build
Old Mar 24, 2012 | 07:56 AM
  #51
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: 305 LB9 300 HP build
Originally Posted by Sojer
I was going t gasket match it but its a 305 its only going to suck up so much air and I'm sure the heads and intake flow more than the hp I'm getting. I feel it would be a waste of time its just a cheap 305 build...
Excellent catch cIaRmOaCrZo, I didn't even notice that. Sojer, the reason why you would want to go back in and grind the gasket down to match the ports is because with the gasket sticking out the way that it is, it is now going to cause turbulence that way...
Old Mar 24, 2012 | 11:32 PM
  #52
Sojer's Avatar
Car: 1987 IROC-Z red t-top
Engine: Nothing much
Transmission: I wish t56
Axle/Gears: 9bolt 3.27 4sale
I thought about that to race season is here and ppl pulling the stangs out I just want my car back. To day I only have bout 30mins on it but I found out that the fuel lines was backwards. It fired like 1 cyl but the timing was not set so its on and popping Monday I will try and get it on vid
Old Mar 27, 2012 | 11:36 PM
  #53
Sojer's Avatar
After 2days of firing still no start. Took the dizzy out and got it to point to cyl #1 so I hope it fires 2morrow. I will try to catch it on vid.
Old Mar 28, 2012 | 05:53 AM
  #54
After 2days of firing still no start. Took the dizzy out and got it to point to cyl #1 so I hope it fires 2morrow. I will try to catch it on vid...
Yes, throw up a video if you can...
Old Mar 28, 2012 | 01:46 PM
  #55
Sojer's Avatar
i lost fire help!!! i made a vid but it didnt fire up if u want to see it i will post it
Old Mar 28, 2012 | 02:44 PM
  #56
i lost fire help!!!
Now I'm confused...
Post it up...
Old Mar 28, 2012 | 04:09 PM
  #57
five7kid's Avatar
Transmission: 4L80E/4L80E
Pointing at #1 isn't good enough. It needs to be pointing at #1 when the #1 piston is at TDC AND on the #1 firing cycle.
But, if you're saying you don't have any spark, that's a different issue.
Old Mar 28, 2012 | 10:08 PM
  #58
Sojer's Avatar
Yeah tdc comp # I just ran into other probs I will post the vid
Old Apr 6, 2012 | 10:59 PM
  #59
Sojer's Avatar
Still tryingto upload the vid I did not loose spark its just really weak what could be its a rebuilt dizzy all new parts
Old Apr 7, 2012 | 05:19 AM
  #60
Still tryingto upload the vid...
Old Apr 7, 2012 | 07:05 AM
  #61
Sojer's Avatar
<a href=http://s134.photobucket.com/albums/q84/sojer/?action=view&current=video-2012-03-28-11-52-09.mp4 target=_blank><img src=http://static.photobucket.com/player.swf?file=http://vid134.photobucket.com/albums/q84/sojer/video-2012-03-28-11-52-09.mp4 border=0 alt=></a>
Old Apr 7, 2012 | 07:07 AM
  #62
Sojer's Avatar
Old Apr 7, 2012 | 07:08 AM
  #63
Sojer's Avatar
http://static.photobucket.com/player...8-11-52-09.mp4
Old Apr 7, 2012 | 07:13 AM
  #64
Sojer's Avatar
I don't see how this helps but if it does. It sounds like a car that has no spark or fuel
Old Apr 7, 2012 | 08:08 AM
  #65
I don't see how this helps but if it does. It sounds like a car that has no spark or fuel...
A couple of things for you to try. First, pull the coil plug wire off of the distributor and stick a flat head screwdriver into it until it is firmly positioned on the terminal inside the boot. Have your buddy turn the engine over again, and listen for spark, you will know if you have spark immediately or not. If you don't have spark, check your electrical connections, ignition module, and the coil itself. If you do have spark, move on to the next thing to try. Two, spray a little fuel into the throttle body (you can use carb cleaner), then try to start the engine again. If the engine starts, then either your injectors aren't opening, or you have a fuel pump issue. If the engine doesn't start, then you have a timing issue. Either the rotor under the cap is off 180 degrees, or you still need to advance or retard the cap to find TDC.
Edit: Regarding that clicking noise in the beginning, check your IAC valve...
Last edited by Street Lethal; Apr 7, 2012 at 08:25 AM. Reason: added information...
Old Apr 7, 2012 | 11:34 PM
  #66
85 Frankenstein's Avatar
Car: 1985 Camaro Z28
Engine: 1988 305 TPI
Transmission: 1993 T-56
Axle/Gears: 3.08
about the weak spark post, I had a bad coil drive me crazy last summer, it was a six month old msd. I would put a spark plug in the wire directly from the coil and it would spark bright blue, when I would check from the regular plug wire I would get nothing. I thought it was the cap at first. I had to call msd for the specs and it checked bad, you can test you coil by checking the primary and secondary resistance, dont remember them off hand but i'm sure you could find them if you searched around here.
Old Apr 7, 2012 | 11:58 PM
  #67
Sojer's Avatar
Ok man MSD stuff goes bad a lot but most I here bad is from LT1 motors I will just get all new stuff again its all new its warranty so I will try Monday. Have a few other bugs I have to get done. 1 is my plastic vss to my trans I can find it or I get wrong 1s so junk yard diving monday
Old Apr 11, 2012 | 10:27 PM
  #68
Sojer's Avatar
Will not start spark still weak I replaced everything it back fired when it was a tooth off
Old Apr 12, 2012 | 11:21 PM
  #69
Axle/Gears: 3.08
I set my initial timing like this. Get the Engine at # one TDC (timing mark at the zero degree mark of the compression stroke) with the distributor cap on, I locate the number one terminal on the distributor cap, then I mark the base of the distributor with a marker directly below the terminal. Then I install the distributor so the rotor is pointing at the driver side headlight. Then I rotate the base so the rotor lines up with the mark that corresponds to number one terminal. This should set the initial timing well enough to get the engine started.
Old Apr 13, 2012 | 10:02 AM
  #70
Sojer's Avatar
The rotor only point at a fixed spot its a small cap dizzy and if it was off it would still have strong spark, I did not ground the body to the engine good or the wires to the computer, so I will ground it and try it. The dizzy is in right its been checked a ton of times by outher engine builders. The spark is so weak the timing light won't pick it up. Thanks for the help guys on my way to work (that's where my car is) will make another vid
Old Apr 19, 2012 | 11:29 AM
  #71
Sojer's Avatar
I must have the dizzy in wrong I have to advance it like 20* (counter clock wize) to get it to ignite the fuel here's the vid with other questions
http://static.photobucket.com/player...8-15-30-37.mp4
Old Apr 24, 2012 | 09:01 PM
  #72
Sojer's Avatar
https://www.youtube.com/watch?v=Bkl1...e_gdata_player
Old Apr 24, 2012 | 09:12 PM
  #73
Axle/Gears: 3.08
So you got it running?
Old May 1, 2012 | 09:32 PM
  #74
Sojer's Avatar
Yes
Old May 6, 2012 | 03:35 PM
  #75
Sojer's Avatar
I'm done got it running but it seems to have a intake leak. I can't find it. When I put the 1205 gaskets with the cork valley gasket, it sits too high meaning it not touching eather head. So I tried two it fit jus right but still run like **** so I went to 1 1205 and use rtv no luck. I even used felpro 9617 gasket no luck I think the block might have been redecked. So I will by by boss 92 integra 5spd burning a lil oil for 200 and pull the motor and redo a vortec 350 with my 113 heads and hsr get a used 350 tpi ecu get it reprogramed and try that. or can a maf do it this it was unpluged and running the same I have a new IAC
Old May 16, 2012 | 07:57 PM
  #76
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
have the heads been milled? would explain the gap
Jake_92RS
Jan 28, 2020 10:37 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
gta90
Sep 15, 2015 04:00 PM
kyleb24
Aug 15, 2015 08:24 AM
sreZ28
Aug 14, 2015 07:48 PM
