91 rs 305 tbi to 91 5.7 tpi
so I have an 91 rs and looking to get some more power just like everyone else I found a 91 z28 for 1000$ it runs but it has no title. Im looking to swap the tpi into my car.
I have a few questions
First, the harness and pcm could i just swap everything over
Second, would the original fuel system need any mods
last kinda off topic is a posi or limited slip for the rear where can I get one and if I go to the junkyard how do I know its posi or ls and rear disc brake is there cheap way to do it
Thx guys first swap any any info would be great
Car: 92 Camaro RS
Engine: 350 LT1
Axle/Gears: 4.10
Re: 91 rs 305 tbi to 91 5.7 tpi
To determine if it's posi:
Jack up the rear end (both tires off the ground). Spin one tire forward, if the other tire spins in the same direction, it's posi/lsd. If they spin in OPPOSITE directions, then you have an open dif.
Car: 92 Camaro RS
Engine: 350 LT1
Axle/Gears: 4.10
For 80% accuracy, use the method above.
NOTE: Just want to note that a blown posi will ACT like a open dif. Both tires different directions.
For 90% accuracy, look at the RPO codes and see if it has a posi equipped from the factory.
For 100% accuracy, pop the cover off and check. There's a thread some where on here with images of what a gov' loc / auburn etc look like.
Thx for the Info maybe shouldve just looked it up instead of posting a thread but my main concern is wiring I would use the donor car but no title so im swapping most parts that are better or in better dhape then mine
Transmission: 4L80E/4L80E
There are some detail differences, such as the RS having a VSS buffer and the Z (TPI cars) not. This can be handled by a complete harness swap, including the dash et al. The underhood wiring to the lights & such, and the rear chassis harness would not have to be changed. But, as stated, those should be plug & play between the two cars and those harnesses.
