question about doing a tpi swap in 83
Old Feb 3, 2012 | 01:57 PM
386kustoms's Avatar
Car: 1983 daytona pace car
Engine: crossfire
Transmission: world class 5 speed
so ive searched and searched but have not come across the exact answer i need. i have a 83 dt500 w crossfire auto. i just purchased a 89 gta tpi 5 speed and i am going to be doing the complete swap. engine and trans. my main question is do i have to swap out the entire car wire harness? i will most likely use the instrument cluster from the 89 since it is electric speedo and looks better then the 83 cluster. is there anything else major that i cannot for see in the swap? i have the complete running parts car so i should have most the parts i need.
Old Feb 4, 2012 | 12:12 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
I'll have to admit I don't know what a "dt500" is.
You won't have to swap over the chassis stuff like lights & turn signals. It would probably be simpler to swap over the other stuff so you don't have to repin things. But, I found out the hard way that dash to rear chassis harness connectors changed between '82 & '86, so I'm sure you'll find the same issue between '83 & '89.
ezobens
Aug 19, 2015 10:29 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
Sanjay
Aug 12, 2015 03:41 PM
