2.8 Engine Swap Vibration
Old Feb 5, 2012 | 03:21 PM
kpthook1012's Avatar
Just swapped in another 2.8. My ride is an automatic and donor motor is from a manual. Engine ran real smooth before pulled. Now I got a real bad vibration that is kicking my ***. Pulled the motor and ran it on the stand and vibration is gone. Only vibrates while installed. Any ideas?
Old Feb 5, 2012 | 03:36 PM
MadCelt's Avatar
Re: 2.8 Engine Swap Vibration
I assume you've inspected your motor mounts and other obvious stuff... Try running it in the car w/ the tranny disconnected? Flywheel? Etc?
Old Feb 5, 2012 | 04:00 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
What year 2.8 did you have and what year is the new one? I did this swap too and I needed Nother flywheel because my factory was a weighted flywheel because it was externally. Alanced and my new engine was internally balanced, check it out
Old Feb 5, 2012 | 07:01 PM
ex-x-fire's Avatar
Yeah some years have weighted flywheels or nuetral flywheels.
Old Apr 3, 2013 | 06:27 PM
camaronate85's Avatar
Having the same problem, but i went from auto matic to standard. U get a fix? Been told its either a fly wheel or drive shaft.
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
db057
Aug 22, 2015 08:17 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
