305 TBI to 350 swap.
Old Feb 10, 2012 | 06:37 PM
Shadyredeyes's Avatar
Car: 1987 Camaro Iroc Z28
Engine: 350 S/B
Transmission: 700 R4
Axle/Gears: 2.43 Gear Ratio
So I'm having to at minimum rebuild my heads in my 88 S/C. I've got a 350 short block just sitting in the garage begging for attention. I'm on a small budget so I'd like to not waste my $ on the 305 and build the 350 instead. My main concerns are, what, if anything can I use from the 305 to put on the 350? I don't have an intake or heads for the 350, so is it possible to build it as a TBI at a reasonable cost, or should I just build it carbuerated instead? Does anyone know about what it would cost to build, and swap the motors?
Old Feb 10, 2012 | 09:52 PM
Engine: 350 S/B
Re: 305 TBI to 350 swap.
Would it be possible to use my 305 heads on my 350, or should I look for a better set of heads?
Old Feb 11, 2012 | 03:52 PM
budget builder's Avatar
Car: 91RS
Engine: carb'd 357 vortec
Axle/Gears: 3.42 posi
get better heads vortecs will outflow anything on your 305 build the 350 no need to throw money away on the 305. vortecs are 600 dollars out of the box or dirt cheap out of the junk yard. let us know how it goes im going to attempt my very first 350 build myself over the summer and im going to ask every question i can. oh and not much other than maybe the accesseries (starter,alt,ps pump,and etc) the 305 was too restrictive.
Old Feb 11, 2012 | 04:53 PM
355sleeper's Avatar
Car: 1991 camaro rs
Engine: twin turbo 406
Transmission: th400 w/brake 4400 stall
Axle/Gears: 3.42s
good choice, im currently build a 355 and using the gm vortec heads. i bought the jegs ez kit. it was 860 for the complete top end, included all gaskets and bolts
Old Feb 11, 2012 | 05:13 PM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Almost everything you need to know is in this sticky tread https://www.thirdgen.org/forums/tbi/...-350-swap.html
305/350 TBI intake and TB are the same, the restriction comes from the heads and the ridicoulous cam. For up to 280fwhp, do not even waste time looking for a different intake.
Vortec heads will require to use a vortec intake manifold, can find basically everything covering that set up here https://www.thirdgen.org/forums/tbi/...i-buildup.html
Some reading in the TBI forum will give you a good idea of what you are dealing with.
Old Feb 16, 2012 | 08:25 PM
Engine: 350 S/B
So I got me a 350 aluminum intake and TBI today along with all sensors and thermostat/housing. All for $30......steal!
Glowsock
Jul 24, 2025 03:15 PM
xkingcodex
Feb 12, 2020 07:43 PM
pimp2303
Jul 27, 2017 02:03 PM
92purpz28
Aug 11, 2015 02:30 PM
