Mystery Heads no info Need help!
Car: 86 IROC-Z
Engine: 383 Stroker Vortec
Transmission: 700r4 Built
Axle/Gears: 3:42
Alright im currently tearing down a 1970 350 outta what im told is a impala motor. i ran the numbers on the block and it is a 350 from 69-79 but when i went to run the numbers off the heads i could not find any info anywhere the numbers are 8678487 or possible the 6 is a 8 also it really hard to tell but ive run each variation and cant come up with any info on them.. if anyone can help me out on any info on these heads id reall apperciate it!
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Mystery Heads no info Need help!
Closest numbers I can see that may match and be in the same era is 3973487 used on 71-72 350 LT1, 75cc chamber
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Nothing here... http://www.chevy-camaro.com/chevy-ca...es.asp?group=1
diana227vegas
Jul 8, 2016 12:27 AM
ambainb
Apr 25, 2016 09:21 PM
509 camaro fan
Sep 6, 2015 10:43 AM
